Testing for a particular bit in a byte value
Hi,
How do I test for particular "BIT" of a value is set to 1 or 0??
e.g. I have a 4 bit value ..
Value := $0111
I want to test if a particular bit of any of its 4 bits) , to see if its a 1 or a 0
Lets say I want to check the 3rd bit ( starting from the left )
How do I do this? Do I use BITWISE DECODE?? or maybe bitwise AND?
Dave M
Value := $0111
Dave M
Would this be what I need to do ( I don't see why I would have to shift left at all)
e.g. To test the first ( Leftmost) bit
MyValue := %1010
IF MyValue & %1000 == %1000
This if statement above would test TRUE as the first bit is 1
or to test the 2nd bit from the left
MyValue := %1010
IF MyValue & %0100 == %0100
would return FALSE as the 2nd bit is 0
etc..
Regards
Dave M
Your idea of shifting left by the number of bits makes sense so you can see what bit you are testing for as well as keeping the code generic.
Dave M
wouldn't this do,
IfNot Myvalue>>4
myValue:=%0100
and you did
if myValue>>2
then it would work but if you had
myValue:=%1100
then it wouldn't work.
You could do
if (myValue>>2)&1
You would have to check to see exactly what 'ifnot' checks for as well.
In 99% of cases that's exactly what you do.· Better yet, set up a named constant for the %1000.
If you did have to be adaptable to check any bit, SPIN has an operator that sets a single bit by number.
|<0 gives %1
|<3 gives %1000
|<31 gives %10000000_00000000_00000000_00000000
So you could do:
MyValue := %1010
IF Myvalue &·|<3
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
So what you first said was :-
Mybit :=(myvalue>>Mybit)&1
I think.
regards
Ron
pub testbit(value,bit) result := value & |<bit
Any nonzero result is true though you could promote it to a true true [noparse]:)[/noparse] with:
result OR= 0
use it like this:
if testbit(mybits,2) do_this_because_its_set
The above statement does not need to compare testbit to a true or false because the result of testbit is true or false. If the bit is set then the result is true.
*Peter*
Thanks everyone!
I think that BITWISE DECODE is the go for this!
I just have to remember that the first bit ( starting from the RIGHT ) is bit 0 not 1
|<0 First bit starting from the right
|<1 2nd bit
|<2 3rd bit
|<4 4th bit etc..
So..
IF MyValue |<3
would result in TRUE if the 4th bit from the right is set to 1
is this correct?
regards
Dave M
that should be..
IF MyValue & |<3
Dave M
Paul Baker
