STATSulator training log
I made a bs2 lcd display to display my training log.
It used a php mysql frontend:
Then I use a php script to grab some values, rebuild a bs2 file and use bstamp on linux to reflash the stamp, so it does not need to be tethered to the pc.
If you are interested you can check out some more of the build over on instructables.com
thanks for looking.
-Joe
thanks for looking.
-Joe
Rebuild a bs2 file and use bstamp on linux to reflash the stamp
How do you UPDATE the Basic Stamp with new Data
What·Linux program dose·this part for you
Very Nice Project
I Like how you had a problem and the way you deal with it
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/27/2008 5:29:39 PM GMT
What I do is use a php script to query the DB and create a new bs2 file. I then use bstamp_tokenize to compile it and then bstamp_run to load it over serial to the stamp. Then I can move the stamp/lcd any where I want and online have to be hooked the computer to update it.
-Joe
Thank You for your reply
So let see if i got what you have done here
You have built something that will remind you of your Goals are
With out have to look on your computer
··Thanks for any·
Sam
