JVM for prop - Page 7 — Parallax Forums
JVM for prop
15791011
  • deSilvadeSilva Posts: 2,967
    edited 2008-02-25 02:31
    To me this sounds like a "Crossroad":
    - Either emulate the VP "in the spirit" of the JavelinStamp, with some restrictions, also possibly needing external Hardware... ("Closed System") This has a huge advantage for an "out of the box solution", also taking advantage of existing documentation... It is in the spirit of a VM, but crippling the Propeller, as with all emulations
    - Or define a framework (= interface) where a user can plug-in his Assembly Code for a COG, so he can define his own VM ("Open System"). There should be more than one VP per COG. A "reference implementation" is also required, of course smile.gif
    edited 2008-02-25 02:33
    CJO said...
    ...get the prop stamp on monday or tuesday and then have some documentation in a day or two
  • jazzedjazzed Posts: 11,803
    edited 2008-02-25 03:02
    @deSilva,
    That is a fascinating idea with great possibilities ... for a future phase. One of the reasons
    we've gotten where we are is because we have a well defined specification. Until we meet
    that specification, we shall not wander far off course. As you know, correctly specifying a
    product is almost as hard as producing it. I've seen many multi-million dollard disasters.
    Phase I first. Phase II is for the wish list. Your idea certainly merits phase II consideration.
    jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
    Traffic is slow at times, but Parallax orders·always get here fast 8)
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-02-25 07:08
    I did some calculations:
    On the javelin with 25MHz clock, 217 clockcycles make up 8.68 usec.
    On the prop with a 80MHz clock, (80/25)*217 = 694 clockcycles make up 8.68 usec.
    If each instruction in PASM executes in 1 clockcycle, as do most SX instructions,
    there should be more than enough time to·run all VP code in a single COG.
    This cog would emulate the SX48 interrupt routine.
    Since the VP code only deals with the vpRambank registers,
    and we·want the same flexible use of VP as on the javelin, meaning any type of VP
    can be started while there are free banks, the following outline in spin code
    should be·implemented in PASM.
    CON
    · 'Virtual Peripheral types
    · NONE·· = 0
    · TIMER· = 1
    · ADC··· = 2
    · DAC··· = 3
    · PWM··· = 4
    · UARTRX = 5
    · UARTTX = 6
    OBJ
    · jd: "jvmData"
    DAT
    · vpBank· byte 0
    PUB isr | i,type
    {{ Run all VP code }}
    · repeat
    ··· waitTick 'wait for 8.68 usec tick
    ··· repeat i from 0 to jd#MAX_NUM_VPS-1
    ····· vpBank := jd#nmPeriph0Bank + (i<<4)······················ 'set currently accessed bank
    ····· type := jd.readRegister(vpBank + jd#nmPeriphISRVec) & $0F 'nmPeriphISRVec holds VP type
    ····· case type
    ······· NONE:·· vpNone
    ······· TIMER:· vpTimer
    ······· ADC:··· vpAdc
    ······· DAC:··· vpDac
    ······· PWM:··· vpPwm
    ······· UARTRX: vpUartRx
    ······· UARTTX: vpUartTx
    ······· other:
    PRI waitTick
    {{ wait until 8.68 usec have passed since last call }}
    PRI vpNone
    {{ optional: wait an average time to minimize jitter }}
    PRI vpTimer
    {{ increment 32bits timer in bank specified by vpBank }}
    PRI vpAdc
    PRI vpDac
    PRI vpPwm
    PRI vpUartRx
    PRI vpUartTx
    To enhance (eg. in phase II) we can add the ability to include a userdefined set of additional VP's,
    which would then run in a different cog from the default VP's.
    regards peter
    edited 2008-02-25 08:27
    I solved the try/catch/finally issue.
    The stored values were not offsets but absolute addresses, so I needed
    to compare those against jvmPC.
    Attached is the updated jvmException file.
    The only issue still standing is when using 'step over' in the source level debugger.
    This combines activity setting kRun with breakpoints.
    I will focus on that next.
    regards peter
    Post Edited (Peter Verkaik) : 2/25/2008 8:37:28 AM GMT
    edited 2008-02-25 14:58
    Peter Verkaik said...
    The datasheet says 4 clock cycles for xor and many typical instructions.
    Measuring xor pin toggle time with pll16x, infreq 5Mhz, I see 4 clock cycles.
    It seems·that for similar ASM in one cog, Prop will run slower than SX48b.
    edited 2008-02-25 15:14
    Then actually the prop appears to run @20MHz giving (20/25)*217 = 174
    But the prop can test multiple flags (c,nc,z,nz) in a single instruction (which the SX48 cannot).
    That should be enough to make up for the missing cycles (I hope).
    regards peter
    edited 2008-02-25 16:48
    Debug 'step over' works now. Only when using try/catch and there is a catch
    the 'step over' continues to run further than one line. This is due to dropped
    frames by the exception handler. (this is also so for a true javelin).
    regards peter
    jvm.zip 49.1K
    edited 2008-02-26 11:19
    I let jvmEngine return a positive value in case a native function must
    be performed. So native functions are now executed from jvmMain.
    The advantage of this is that only jvmMain needs editing for adding
    new native functions (by including a new object for the new functions).
    I also moved some constants that are local to specific objects, from
    jvmData to those object.
    The java method Terminal.getChar() is working, so it is possible to
    use user input in the java programs.
    The attached java test program will demonstrate this.
    I believe the jvm now fully supports the bytecodes generated by
    the javelin IDE. Some native functions may not work. The Virtual Peripheral
    code needs still to be written. But it is possible to write java programs
    that only require terminal input/output (such as the attached java program).
    The source level debugger·is also working.
    Edit: I also attached the latest Javelin IDE.
    To use that, first install IDE version 2.0.3 that you can download from here:
    http://www.parallax.com/tabid/443/Default.aspx
    Install version 2.0.3 and then unzip javelin.zip into the IDE working folder.
    Download the jvm firmware into the propeller using the proptool.
    Then startup javelin.exe instead of "Javelin Stamp IDE.exe" from the working IDE folder.
    regards peter
    Post Edited (Peter Verkaik) : 2/26/2008 12:02:14 PM GMT
  • Robot FreakRobot Freak Posts: 168
    edited 2008-02-26 12:37
    Are you saying all java-only bytecodes are working?
    So the following things can be used:
    - declaring variables (int, char, String, arrays)
    - declaring void and int methods
    - declaring objects with local variables
    - doing math with variables
    - using statements (if, else, do ... while, while, switch)
    The modified Javelin IDE can recognize a PropJavelin, and download java programs into memory?
    If so (or maybe some points not), you all have done a great job in such a short time!
    Kind regards,
    Robot Freak
    edited 2008-02-26 13:18
    That's right. All·javelin constructs can be used.
    The same limitations apply: ints are 16bits, no floats or longs for now.
    The new javelin.exe has additional commands:
    Project->Download to RAM
    Project->Program to RAM
    Project->Debug to RAM
    to support the propeller's ability to download only to ram.
    Using the regular commands will copy the bytecodes into propeller eeprom.
    At the moment the JVM provides a 16KByte memoryspace for the bytecodes.
    (The javelin has 32KByte memoryspace).
    There are still more than 1000 longs free so that space could be cranked up to 20KByte.
    I hope once alot of the spin code is converted to PASM that we can
    crank it up·to 24KByte.
    regards peter
    edited 2008-02-26 14:15
    Wow, that's great you can confirm that.
    One these days I get a pair of Protoboards to start testing the JVM.
    All CPU native methods are done, and it looks like the PWM VP is ready?
    edited 2008-02-26 14:22
    Most native functions have code (in spin) but these need to be tested.
    No VP code is available, meaning there also is no Timer. Since most
    native CPU methods depend on a 8.68 usec tick, that needs to be realized
    first. The CPU.readPort(), CPU.writePort(), CPU.readPin(),·CPU.writePin(),·CPU.shiftIn(),·CPU.shiftOut()
    have code and do not rely on the timer tick, so these may work but they
    need to be tested to be sure.
    regards peter
    edited 2008-02-26 14:39
    After downloading the new IDE, I unzipped it, placed it in the existing IDE folder and renamed it.
    After starting I get the message "Unable to open file (null)".
    I tried clicking on "New" three times, the same error.
    After clicking on "Open" and selecting a file, I get about the same error.
    Did I do something wrong?
    Kind regards,
    Robot Freak
    571 x 129 - 22K
    edited 2008-02-26 14:42
    You probably have no printer installed in windows.
    Go to start->settings->printers
    and install a generic/text-only printer
    Then restart the IDE and you should have no trouble.
    regards peter
    edited 2008-02-26 14:53
    I've got a network printer installed,
    I tried setting the "Microsoft XPS Document Writer" as default, but the same error comes up.
    Kind regards,
    Robot Freak
    416 x 106 - 7K
    edited 2008-02-26 14:57
    In that case, startup the IDE, goto Project->Global options.
    A window pops up. Click OK. Exit the IDe. Restart the IDE.
    That should do it.
    regards peter
    edited 2008-02-26 15:04
    That did it, thanks.
    Trying to download to my Javelin, but it didn't work.
    So I guess this IDE can only be used with the PropJavelin?
    Kind regards,
    Robot Freak
    edited 2008-02-26 15:27
    It should work also·with a true javelin.
    You need to make sure·the javelin is on the first available
    com port (See Project->Global option, tab debugger, edit port list).
    Even if you use Project->Program to RAM, when it connects to
    a true javelin it will do Project->Program as you would normally use
    with the javelin.
    I usually edit the port list to only include the comport to which the device is connected.
    Try Project->Identify.
    If it finds a true javelin it should show version $50.
    For a propeller/spinstamp programmed via the Propeller TX/RX pins
    (setting commPort = 1 in jvm·spin program) the version is $78.
    For a spinstamp programmed via the SOUT/SIN pins (setting commPort = 2 in jvm program)
    the version is $70.
    regards peter
    edited 2008-02-26 15:58
    I always made a list with the ports from 1 to 14, to make sure that the IDE found my Javelin.
    (because my laptop assigns a different number each time I reconnect the USB2serial device)
    After deleting the others, it worked.
    Thanks!
    Kind regards,
    Robot Freak
    edited 2008-02-26 18:41
    re Propeller timings.
    The timing of Propeller instructions is well known.... What is not well known is how they compare to an 8-bit machine. The enormious advantage of 32 against 8 bits cannot always be utilzed! On the other hand allow the conditional instructions terrific shortcuts.Third: The propeller instruction set is not well suted for VMs... Fourth: There is the panalty for HUB accesses. To write fast PASM code needs some good experience with it..... After reading the above I should not expect the Propeller VW running faster than the SX
    edited 2008-02-26 20:00
    @DeSilva, since you have better knowledge of PASM than me, do you expect
    a PASM JVM would yield the same speed, or even considerable less?
    I think you are right that hub access will put the greatest limit on the speed,
    so someone with detailed knowledge of PASM should do the conversion to PASM,
    and that isn't me.
    The·JVM is running properly at this moment so I think we can keep it in this
    state so it can be·converted. The fact that some native routines are not working
    or not tested to be working should be not a problem for the JVM itself.
    regards peter
  • simonlsimonl Posts: 866
    edited 2008-02-26 22:04
    I think Peter's just set you a challenge deSilva!
    @Peter: Astonishing work. I'll _have_ to learn Java now smile.gif
    Cheers,
    Simon
    www.norfolkhelicopterclub.co.uk
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
    BTW: I type as I'm thinking, so please don't take any offense at my writing style smile.gif
    edited 2008-02-26 22:12
    Javelin java is much simpler than pc java: no interfaces or implementations.
    It's more like C with classes and objects.
    regards peter
    edited 2008-02-26 22:40
    I hear you Peter - I've already downloaded the Javelin doc's and will be studying them over the next few weeks and months I guess.
    Thanks again.
    Cheers,
    Simon
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2008-02-27 14:23
    @Peter, Jazzed and others in the Javelin Group.
    Hi
    I am complete Javelin Novice I have a read of the Javelin Stamp Manual today got the Prop JIDE up and running.
    I don't seem to be able to access pins above 0..15, am I missing something ?
    Could it be that there are only 16 pins available on Stamp ?
    Compile Error Stamp/core/CPU .......no pin19 defined
    Regards Ron
    edited 2008-02-27 14:42
    The true javelin has 16 I/O pins, and pins SOUT, SIN and ATN.
    Those last three are also available on the spinstamp (for System.out.print and Terminal.getChar).
    Support for propeller pins 16-31 is scheduled·for later,
    that is when all native functions and VP code runs, as if the
    propeller was a javelin.
    regards peter
    edited 2008-02-27 15:45
    Peter said "Support for propeller pins 16..31 is schedued for later, that is when all native functions and VP code runs, as if the propeller was a javelin"
    That explains everything, thanks.
    regards
    Ron
    edited 2008-02-27 21:09
    Attached is the jvmVirtualPeripheral spin file.
    For the DAC I have inserted the vpDac method that needs to be converted
    to pasm. This is a very simply task, the pin output is set to the overflowbit
    after adding the dutycycle (0-255) to the·accumulator.
    The idea is that this code is executed every 8.68 usec if the DAC is installed.
    Who can help in translating this method into the most optimized pasm code?
    Also, the method isr needs to be converted to pasm. isr the entry routine that
    is to be started in a new cog from another spin file.
    I also added code for method vpAdc. That too needs to be converted.
    regards peter
    Post Edited (Peter Verkaik) : 2/27/2008 9:46:22 PM GMT
  • KaioKaio Posts: 287
    edited 2008-02-28 00:09
    Peter, Jazzed,
    a short update from me. I'm currently testing the first PASM bytecode decoder. I have put the bytecode handler til Jem_SWAP in one cog. If I have this sucessfully tested I'll publish it and you could test it with some little Java progs. In the next two days I'm to busy to proceed the testing. But on the weekend I'll have more time.
    @Peter
    Good progress of coding vp's. It would be helpfully if someone could translate this to assembly.
    Thomas
