SX-Key or SX-Blitz — Parallax Forums
SX-Key or SX-Blitz
richaj45richaj45 Posts: 179
edited 2008-02-27 02:22 in General Discussion
Is the SX-Blitz worth the lower cost then the SX-Key?
That is, is the key used for debugging when you want accurate timing or when operating over 50Mhz.
I am trying to by the Blitz which is available or wait for the new Key to be available.
Please comment.
cheers,
rich
  • JonnyMacJonnyMac Posts: 9,767
    edited 2008-02-27 01:05
    If you're serious about development wait for the Key.
  • PJMontyPJMonty Posts: 983
    Rich,
    Ditto what JonnyMac said. The SX-Key allows you to do full hardware debugging of your running program. you can single step, walk, run and set a breakpoint on the actual code running on the actual chip. The Blitz will only program, leaving you to debug using much more primitive techniques (Guenther's SX-Sim not withstanding).
    PeterM
