Propeller and Encoder
Im trying to use a Propeller to read an encoder I pulled from a dead HP printer. I included pictures of the encoder and the pinout on the back of the chip.
My problem is that I cannot find any literature on the encoder for what pin is what. Its just a linear encoder on a cheap printer, so I cant imagine it being this difficult. Any ideas would be great!
Thanx!
Thanx!
*Peter*
One other thing, on the printer I hacked the quadrature outputs were analogue so I used a comparator to convert them to digital (set the reference to supply/2 using two resistors).
Graham
Check out http://sharp-world.com/products/device/catalog/index.html
As you mentioned that it is a HP printer it could well be an AVAGO part as well.
There is some text on the side of the encoder is it Agilent ?
Agilent is a HP company ( or was part of that group..)
The SHARP company has the lion share of the market when it comes to small linear sensors
as used in copiers printers... but they also make 5_000_000 variants so good luck with finding the data.
Hopefull this might help you a little to get started ..
Cheers Ron Mel OZ
Post Edited (OzStamp) : 2/25/2008 10:23:07 AM GMT
