A New Transformerless Power Supply Concept
Lately, I was thinking of such a device, but it's not a SMPS.
A AC mains 110v or 240v supply could be used to heat up an enclosed container using an heating element.
Then a thermopile will convert the heat back to some low voltage DC like 5V that can be used by common electronic appliances.
The result would be ripple free.
What do you guys think?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
- Stephen
The theoretical best any heat engine can ever do is 40% - again that's a law of physics, from thermodynamics. Switch mode power supplies can achieve 85% or greater efficiency without violating thermodynamics because they are not heat engines.
Anyhow it's good that you're thinking outside the box, but this is an over complicated solution to a non-problem. You can achieve low enough ripple to power any common electrical circuit using good filters on a switch mode supply, or go with linear regulation if you're paranoid.
If for some reason you had something like a scientific experiment that absolutely requires ripple-free power, just use a battery!
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
