Basic Stamp: Biology teacher wants to record bird song--any advice?
Hi Basic Stamp community.
I am a high school biology teacher and I want to use Basic Stamp 2 to record bird songs. I need helpful advice in the following areas:
1. Cheap input mic (quality of sound is not important) and program code for the Basic Stamp
2. Clock chip and simple program to tell the Basic Stamp when to record (say every hour on the hour for 1 minute)
3. Flash memory storage of some sort and instructions/code to get Basic Stamp to send file to Flash memory
Any advice you may have would be much appreciated! I hope to turn on some of my students to the idea of "remote sensing".
Elliot
Elliot
There are plenty of examples in the various Stamp tutorials of a Stamp controlling a relay and using a real-time clock/calendar. I believe the StampWorks manual has examples for a clock and the Industrial Control manual has plenty of examples of a Stamp controlling a relay or solenoid or motor.
"I hope to turn on some of my students to the idea of "remote sensing"."
Excellent. I think that's a very admirable goal.
I wonder if there is a simple, cheap, mP3 recorder available to do the recording and if I could hack into the circuitry so as to connect it to the basic stamp??? On another post I seem to remember a rocket project in which a $10 camera was hooked to the basic stamp to capture photos during the parachute phase of the launch. The designer had opened up the camera and figured out how to have the basic stamp press the right buttons. Hmm.
I appreciate your assistance!
Elliot
Radio Shack makes a record/playback module for $11.· This should work easily with the Basic Stamp to record your bird songs.
Daryl
If it really is that cheap I could afford to purchase more than one in case I blow it out when trying to figure out how to hot wire it. Do you know what the device is called?
Elliot
It's a nice unit, but very limited in how much it can record. You can buy larger chips, up to about 2 minutes, and a Stamp can control them to record multiple phrases. I suspect you want something with a larger capacity.
I know you can buy a nice MP3 recorder controller that plugs into an iPod and that could be hacked using a reed relay in place of a button push (www.griffintechnology.com/products/italkpro). iRiver (www.iriver.com/product/) also makes several lines of tiny MP3 compatible recorders that could be similarly hacked if you've got a steady hand with a small soldering iron.
You won't blow it out, but I'm not sure it'll be capable of doing the recording you want. It'd be a good educational tool for students to learn with, though.
EB
