Handheld Props — Parallax Forums
Handheld Props
RaymanRayman Posts: 16,139
edited 2008-12-28 00:40 in Propeller 1
Recent talk about cutting up Proto boards gave me an idea...· Check out my cut up Proto board in a Hammond 1553 case with Nokia display.· There are side ports for PropPlug and keypad...··· I wish I'd put the screen in 180 degrees around now though (so there'd be room for a 12-key panel mount keypad...).
I put a Prop Oled in a smaller one, but somehow damaged it in the process...· The screen is extremely dim now.
    edited 2008-02-17 01:24
    Just finished mine tonight.. Or at least got it up and running..
    (When is a propeller project ever finished???)
    It slides into a 10pin female header for easy removal for work.
    Currently my SD socket is a little skitzo, but it works most of the time.
    It's fully connected to sound and the PDA keyboard you see in the shots.
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook
    Got an SD card? - PropDOS
    A Living Propeller FAQ - The Propeller Wiki
    (Got the Knowledge? Got a Moment? Add something today!)
    816 x 616 - 80K
    816 x 616 - 94K
    816 x 616 - 76K
    816 x 616 - 60K
  • rjo_rjo_ Posts: 1,825
    edited 2008-02-17 04:33
    That's what I call rapid prototyping[noparse]:)[/noparse]
    I think you guys just set some kind of record... somebody needs to call the Guiness people.
    Rich
    edited 2008-02-17 04:36
    Why are there wires going from the keyboard to the computer?
    edited 2008-02-17 13:54
    *wires*
    Only because I don't have the IR interface stuff installed and working yet.. [noparse]:)[/noparse]
    (Still breadboarding that part.. [noparse]:)[/noparse]
    OBC
    edited 2008-02-17 17:32
    I just couldn't "resist"... [noparse]:)[/noparse]
  • AbelAbel Posts: 15
    edited 2008-02-25 00:20
    Here is my Handheld Propeller powered GPS System.·
    Front view: The all important Propeller Powered Sticker by Phil (thank you roll.gif ), a Micro DataPad Mini Keyboard for Palm PDA m100 for user input, and a uOLED-128-GMD1 display.
    Inside view:· upper left Parallax GPS reciever Module, lower left a Propeller Demo Board and on the lower right rechargable batteries.
    Screen view:·GPS Module output showing heading·and current position along with··calculated bearing and distance to destination.· only 1 cog·free for further development. confused.gif
    Thanks to all who shared their knowledge in the Almost Free Keyboard, GPS, uOLED·and Floating Point related posts.
    Post Edited (Abel) : 2/25/2008 12:55:19 PM GMT
    408 x 602 - 33K
    640 x 480 - 140K
    640 x 480 - 129K
  • mcstarmcstar Posts: 144
    edited 2008-12-27 23:15
    Does anyone have one of the Micro DataPad Mini Keyboard for Palm PDA m100 for sale? Know where I can get one?
    edited 2008-12-27 23:33
    bean should still have some, if not PM me and I'll make you the same deal
    he has.. I'm sure I still have a couple unopened units in my shop somewhere. [noparse]:)[/noparse]
    OBC
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card connected? - PropDOS
    Very nice - thanks for sharing your pics :-)
    Prop Tools under Development or Completed (Index)
    http://forums.parallax.com/showthread.php?p=753439
    cruising][noparse][[/noparse]url=http://www.bluemagic.biz]cruising[noparse][[/noparse]/url][/url]
    This is a [noparse][[/noparse]b]bold[noparse][[/noparse]/b] test.
