DS 1302 runs fast...
I have a couple of different devices that use the DS 1302 Time chip.· Both devices will gain time.· About 5 minutes in a 3 week period.· I know, not much, but enough to require resetting the clock.· I am using the recommended crystal, etc.·
Has anyone experenced this problem with the DS 1302?
Other then that, the operation is normal.
Deno
Deno
I've got two clocks running off DS1307s, and they keep time to around 1-2 minutes per month fast. They're in the basement, so the temperature is fairly constant, around 68-69 degF.
Deno
I have noticed that in several projects I have the DS1302 in there is a minimal gin of time per month, however if the main power should go out, that gain jumps. For example, one day the power was out for several hours. When it came back on the clock was about 3 minutes fast. I have considered trying one of the more accurate clock chips from Maxim/Dallas, but they’re SMD. So far I’ve just accepted it. But for someone who has used the DS1302 in countless projects I too have seen some gain in time and I also have followed the AppNote regarding crystal placement/layout. Take care.
Chris Savage
Parallax Tech Support
Deno
