Using a phone cord for a servo cable extension?
I need about 60" of servo extension and I'm having a hard time finding an official servo cable extension at that length. So my thought is to use phone cord instead, or maybe a pari of speaker wires? Is there any drawbacks to this? Will it work ok or are the wires in a phone cord too thin? What types of extension is possible, as far as what do you think my length limit would be?
I am 1010, so be surprised!
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 2/13/2008 5:06:15 PM GMT
Hope this helps
Al
When you used Cat5 for your long servo run, did you use 4 wires (2 gnd , 1 power, 1 signal) or 3 wires? The two gnds would be tied together at both ends...
Terry
Yes, that makes sense. Should have considered it...
Actually I was mistaken; it was a 6-conductor CAT3 cable that I used.· CAT3 is defined as UTP (Unshielded Twisted Pair) cable designed to carry voice and·data up to 10 Mbps.
The particular cable that I used was 24AWG.
Reference Thread:
http://forums.parallax.com/showthread.php?p=549166
1 - GND
2 - PWR
3 - Servo1 signal
4 - Servo2 signal
5 - Laser Power
6 - Not Used
Jed,
For the 5ft (60 inches), and 2ft (24 inches) the capacitor is probably not as necessary.
With long runs (30feet) you start to experience IR drop.· To compensate for this,·a local bypass capacitor located in close proximity to the Servos, will usually do the trick.
A series resistor is a good idea, to help attenuate any noise that might be picked up over the wire due to·any antenna effects, or noise from the servo entering the signal line.
Beau Schwabe
IC Layout Engineer
