Beach Chair
I want to build a wheelchair that can travel across sand. I am looking for advice and links. What I am thinking is that the tires need to be wide and independantly driven or a drive train right and left. I visualize the steering being accomplished by adusting speed ratio of opposite sides the turning circle does not have to be too tight.
Initially I would like to be able to transport a 200 pound load for at least an·30 minutes·over a reasonably level sand terrain. I can manufacture a lightweight frame but would like help choosing tires , motors, the best way to gear motor to drive shaft and suggestions on what kind of battery pack I would need. I am wanting the motors to fall within the control of HB25's.
Apart from selecting components gearing is a weakness for me and calculation of motor size and power requirement. Overall weight will be a factor.
I welcome all suggestions
Jeff T
Jeff T
http://www.hotshotproducts.org/product.htm
I am hoping to find a cheaper alternative but in the end will go with what is best.
Jeff T.
- Stephen
On sand all wheel drive is a good idea. Windshield wiper and or power window motors chain driving the wheels is a good place to start.
best of luck
marty
Lunch cures all problems! have you had lunch?
Would windshield motors carry the load, I must admit I was thinking about windshield motors at one point. If so what would be the best battery configuration. I wondered if I might need a deep cycle marine battery or if a regular car battery would do.
Jeff T.
http://www.wheeleez.com/index.php
Magic Smoke Theory of Electronics –
Inside every electronic part there is magic smoke.
The magic smoke is what makes everything work.
If you release the magic smoke, the part stops working!
Have a look at the TETRA Society website. A while ago, one of the chapters built a beach wheelchair to get folks across the sand and into the water. The tires were plastic, I believe and quite wide, but light. I'll see if I can get the link and will edit this message.
· EDIT:·· Can't find the pic of the TETRA beach chair but I did find this: http://www.beachwheelchair.com/
Tom Sisk
Tom Sisk
http://www.siskconsult.com
Post Edited (stamptrol) : 10/13/2007 3:09:36 PM GMT
Hi Kelvin, the physics of this project do concern me and is something I am going to get ironed out before I make too much investment. I have seen electrically powered beach chairs on various web sites so I think electric power is doable. I am not good with gas engines and the thought scares the hell out of me whereas I feel comfortable with the electric option. My initial aim is 2-6 mph for 30 minutes with something like an 16-18in wheel.
I believe the wheels in the link from Mr Richard will ultimately be my best bet. They are low pressure (2-4 PSI) balloon tires designed to travel across sandy terrain with the least amount of effort. The balloon tires weigh approximately 5lbs each as opposed to ATV tires and rims which weigh in at an average of 20lbs each from what I have seen.·I have a couple of questions for Wheelez which I will email today and possibly place an order.
Motor selection is still on my mind and I am debating between a 12v or 24v system, I would like to use the HB25s for control if I can drive the chair with motors that fall within their specification. I have an outline of the frame sketched out which so far has four stub shafts individually driven by chain and sprocket. As things progress I may go to rear wheel drive with a steered front end. Right now I have a lot of flexibility.
Tom I would love to see the TETRA link if you come across it, I know you have modified vehicles before ,do you have any suggestions on motors.
Jeff T.
We have not ruled out the ramp and cart setup but feel the kart design would not be any more difficult to fabricate and will possibly give a little more freedom/independence and a better style. The suggestions are great and we look at everyone of them for ideas.
I wrote to Wheeleez with questions regarding axle and rim configuration, and unbelievably I may have a source for an old electric wheelchair I can salvage the motors from·at no cost.
thanks
Jeff T.
Todrik
What say you ? You asked a question . You should reply to all respondents, last word - if you will.
Todrik
I had an electric wheelchair given to me, so I have motors , rear motor controller and the start of my frame. I have bought some 15" lawnmower wheels with aluminum rims today and currently machining a hub to mate it to the wheelchair. Lack of Parallax hardware right now but I do have plans to add in some features where a BS2 and HB25 will come in handy.
Thanks again
Jeff T.
The rear wheel hub turned out great and so did the castors, which I had reservations about.
I have yet to clean up the upholstery and fit stirrups for the feet,·the controller bracket also needs repair.
I designed an extension to the existing chair that folds back for transporting, still bulky but managable. The whole thing takes about 10 minutes to piece together.
I took it for a test run today, the best stretch of sand I could find in this area and a little firmer than I wanted but it did have a testing slope to it
Youtube video at this link http://www.youtube.com/kylia666
Jeff T.
Great looking project! Really jealous you don't have 6 feet of snow scattered everywhere.
Has your "Boss" had a chance to try it out yet?
Tom
Tom Sisk
Jeff T.
You did a very good job on this Project looks very nice
······························ Youtube video
Looks real good and from what i see it seem to work real good
Thanks for sharing your Project
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/11/2008 5:11:18 PM GMT
Excellent work. It is great to see ideas become reality.
http://planetmobility.com/store/wheelchairs/power/tracabout/index.html
