Hanging projects on deSilva's desk
I just looked through the mess on my desk... After some sorting it looks something like this.. So this is a kind of comittment
Task: Update of "How to Program the Propeller using Machine Language" Status: Unposted, but worked on Obstacles: Need to add more examples Include an appendix for the beginner: "What is Machine Code?" Completion: Before Issue 1 of C-Compiler ------------------------------------- Task: Very small I2C driver in SPIN (30 kHz) Status: Working and posted with Port-Expander and ADC examples Update: Include additional example for EEPROM and Timer-Chip Update: 1Q2008 ------------------------------------- Task: Very small I2C driver in PASM (400 kHz) Status: Working Obstacles: Needs more testing Completion: 1Q2008 ------------------------------------- Task: Package for DOGM 128x64 display Status: Basics are working and posted Obstacles: Deciding compatible interface Waiting for hardware Completion: around Easter ------------------------------------- Task: Interfacing S65 display Status: Not yet started, but 2 displays available now Obstacles: Deciding compatible interface Time Completion: around Easter ------------------------------------- Task: PS/2 Emulator in SPIN Status: Basics are working Obstacles: Needs clean hardware interface Some examples needed (reverse) encoding table for keyboard missing Completion: 2Q2008 (not needed earlier) ------------------------------------- Task: Description of "PropDeSilva", a very low cost development system Status: Concept and prototypes available Obstacles: Verification needed More modules needed Completion: 2Q2008 (but needed then for class) ------------------------------------- Task: Parts for "PropDeSilva" Status: Prototypes available Obstacles: Support needed More module definitions needed Completion: 2Q2008 (but needed then for class) ------------------------------------- Task: Parallel Computing Examples: CA and Simulation Status: Just ideas Obstacles: Needs time Completion: 3Q2008 ------------------------------------- Task: Adding Propellers for Parallel Computing Status: Concept based on "PropDeSilva" Obstacles: Higher Protocols TBD Completion: 4Q2008
Timothy D. Swieter
tdswieter.com
One little spark of imagination is all it takes for an idea to explode
But as anyone knows it can be much faster to write the code you need rather than find out what other's have already done, especially with the Propeller....I2C code will be a very useful example where LMM code (assembly or C) can be used, as it is exactly in that time scale....
Project: MK-95 II - Fully functional Portable RPN Calculator (AVR based)
Status: Prototype works, but most of the math routines are... unwritten. The rest, kbd, display, power on-off, works.
Timeframe: ukn
Project: MK-100 - Fully functional Portable RPN Calculator with graphing capabilities (AVR based)
Status: Prototype works, but no code yet. Graphic display is on its way.
Timeframe: ukn
Project: AmiProp - Portable, programmable Propeller based computer (2 Props, > 128 K RAM).
Status: Prototype built, but not everything works... no code besides inter-prop communication done.
Timeframe: ?? (after March)
Project: Kubus - A propeller based video game (Software only) (Candidate for some LMM goodness)
Status: Some 3d-math written, all ideas about functionality allready in place... needs serious coding
Timeframe; Q1/Q2
Project: Propeller (2 Props probably) based Spectrum analyzer (for my Ph.D) (sw & hw)
Status: Some testing done with ADC, FFT already written, needs display & testing
Timeframe: Feb/March
Project: High performance computer (>100 MIPS), with a Propeller as video controller.
Status: Trying to decide on processor, ARM, AVR32, Coldfire.
Timeframe: no limit
Loads to do.
Ale
