PDB "Vpp Generation Failed" question
Before bothering tech support, I figured I'd ask here.
I'm teaching a class using the SX and the Professional Dev Boards.· We seem to be having trouble with a couple of components.
New PDB used by student.· He keeps getting "Vpp Generation Failed".· If I remember correctly from previous discussions, this means that the Key or Blitz cannot get the higher voltage to the chip to erase and program it. Here's what I tried:
1) Numbered the boards so that I can track problems in the future
2) PDB # 8001 give me "Vpp Generation Failed" when used with both an SX-Key (with USB converter) and an SX-Blitz.· Using 4mhz resonator.
I think I have narrowed it down to the PDB because:
3) When I use thet same SX-Key with another board, the key·works fine.
4) When I use the same SX-Key with another board, the blitz works fine.
5) When I changed the power supply from a 7.5Vdc to 9.8Vdc, I still get the Vpp error.
Did I miss something?
John J. Couture
San Diego Miramar College
John J. Couture
Dave
Dave Andreae
Parallax Tech Support·
Try another SX28 chip in the PDB.
Bean.
www.iElectronicDesigns.com
Dave, no setup (i.e. no wires attached), I purposely wanted to try a blank Prof Dev Board so as to not muddy up the problem.
John J. Couture
John J. Couture
It would seem that it is toast.
Instead of throwing it away it might be worth trying to carefully sanding/filing/grinding down the top to expose the die. The students will get a kick out of seeing what is actually inside the chip.
Bean.
Shawn Lowe
Maybe I should have waited to do that......
John J. Couture
