Flow Control Issues
Im having a problem displaying information from my device (LinkMatik 2.0). The only help I've gotten from their support team is:
To check the flow control, verify the voltages on TxD, RxD, CTS, RTS are as you would expect. (CTS, RTS low, TxD, RxD high.) Use a scope or LED to check whether data is actually transmitted on TxD, RxD.
All of the pins are set correctly (CTS/RTS - low ; TxD/RxD - high), however I do not see any changes when I check whether data is transmitted on TxD/RxD via LEDs. My baud rate is set to 9600bps, so I assume I cannot see the pins going high and low? How do I check whether my device is receiving data via the serial port?
BCISS
BCISS
Here is how we set up the circuit
Vdd -- R(470 Ohm) -- Diode -- RxD
We also tried slowing the baud rate to 300 bps, just to see if we could slow down the data transmission, but still nothing.
example = 90
SEROUT TxPin\CTSPin, BaudM, [noparse][[/noparse]DEC example, TAB,CR]
By right,
90
should be shown on my Hyper Terminal right? MayI know if my programming code is wrong? Also, how do I write the receiving programming code?
SERIN RxPin\RTS, BaudM, [noparse][[/noparse]example]
by right, i should receive the value 90 and it will be stored in VAR example right?
You have one thing missing. You neglected to define the variable "example", thus it doesn't exist. If it is one byte, then you can declare it this way at the beginning of your program:
example VAR BYTE 'Maximum value 255
If it is a WORD (two bytes) you can define it this way:
example VAR WORD 'Maximum value 65535
Then you can go ahead and set it to any initial value you want, within the above noted range limitations.
Bruce Bates
There is no pleasure in having nothing to do;
the fun is in having lots to do, and not doing it!
