Sound App Module and DiosPro
Hi folks,
Certanly this is an off-topic issue, however I really need some help here:
I had working on a robotic project based on Basic Stamp2, using Sound App Module for feedback purposes. It worked fine but eventually I ran out my I/O ports, so I have migrated the project to DiosPro, a microprocessor like BS2 with steriods... All works Ok except Sound App Module doesn't recognize the Serial commands sent by DiosPro. I have tested the wiring and hardware, it all seems to be ok, but the Sound Module refuse to work with DiosPro instructions.
I guess it is a particular issue related to Sound App Module / BS2, because the byte structure of SEROUT Dios pro command seems to be identical to Basic Stamp.
I reallly appreciatte any advice to workaround on this matter
Thanks in advance
daniel
PD: Of course I had worked this issue with Crustcrawler guys from DiosPro....no results at all
Visit my Personal Home Page:
http://darnoff.vtrbandaancha.net/
Thanks in advance
daniel
- Stephen
I setup the DiosPro ·from 1200 to 9600 and the Sound App Module didn't respond to the commands sent.
If I send the command sequence via BasicStamp2, the module works Ok., so I guess the problem is related to the format or serial protocol used by Dios Pro.
Any other advice from the comm geeks?
Thanks in advance,
daniel
Is it a matter of software or hardware?
daniel
