Twos-Comp Negative Numbers in Data Statements Compile to Incorrect Values
In the current SX/B release, the following compiles and programs, but the values compiled to .src are INCORRECT:
This does compile to correct value:
From SX/B doc...
WDATA/DATA
Creates a table of data values for use with the READ instruction.
• Label is the symbolic name for the table and serves as a pointer to the location of table index zero.
• Const is any constant (byte, ASCII character, or computed value).
...which would lead me to believe the first example should work.
Not a big deal, but this threw some havoc in into some "negative" servo offsets I was using in a data table.
Until I closely examined the .src output, I didn't catch that my code was fine, but the compiled data was not. Have not had a chance to check out in the beta SX/B yet.
DATA -1 ' would think it would compile to $FF, but does not ' etc
foo CON -1 DATA foo
From SX/B doc...
WDATA/DATA
This is fixed in the beta version.
Thanks for pointing it out, I'll add it to the download thread.
Bean.
www.iElectronicDesigns.com
