Prop plug and MatchPort b/g
Hi everyone,
Would it be possible to just connect a prop plug into a "Lantronix Matchport b/g" for serial communication?
The matchport supports the following -
Interface: CMOS (Asynchronous) 3.3v-level signals, rate is software selectable (300 bps to 921,000 bps)
Serial Line Formats: 7 or 8 data bits, 1-2 stop bits
Parity: odd, even, none
Modem control: DTR, DCD
Flow Control: XON/XOFF (Software), CTS/RTS (hardware), none
I would assume that the prop plug -
"reset" pin would go to DTR
"TX" pin would go to RX
"RX" pin would go to TX
and
"VSS" pin would go to VSS
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Sticker
Post Edited (computer guy) : 1/30/2008 8:55:31 AM GMT
and
Thank you
When the matchport requires DTR you can most likely short circuit it with DCD.
RX and TX are o.k. Note that those names describe what the Plug does wrt to that line (acting as an DTE, thought it is an DEE). But the small triangles on th Plug show you the way
So do I connect DTR to DCD all the time? Or only when it is needed, If so how?
For some time now you've mentioned your Propeller Domed Sticker, but your avatar does NOT reflect that image. Missing is the sideways 'INC'. Bet you meant to update your avatar. Been wondering when.
Harley Shanko
Thanks, I kept thinking about updating my avatar, never got the time.
The new avatar is up.
Because not enough people are interested in the "Domed stickers" I will probably have to stop asking about them.
I figure I will give a few more days to get some more requests.
If by then I havent reached the minimum requirements I will pull down the website.
Post Edited (computer guy) : 1/30/2008 11:13:28 PM GMT
