Uart buffer
I had a quick question about extending the Uart buffer beyond its standard size.
I am communicating with a C328 Camera module. I was counting on being able to control package sizes and not overfill the serial buffer before I could read all of the image data I needed. I recently found out though that if I'm retrieving an uncompressed image file (which I am) that it does not operate in package mode. Instead, it will send all 5kb+ (depending on what I set the resolution to). There is no way to stop the camera from continuing to send data if the buffer is close to filled or filled. No handshaking pin and there is no command that I can find that is recognized by the C328 that will stop transmission.
Here is the really short users manual for the C328 camera module:
http://www.electronics123.net/amazon/datasheet/C328R_UM.pdf
In the Uart class itself I COULD go in and change the stdBufferSize property. This breaks some of the other code in the Uart object though and probably isn't recommended to try and change those classes in the first place.
In a perfect world this camera module would actually have some form of handshaking to start and stop transmission.
Is there any way to get around this on the Javelin?
as an array of 128 integers. In my adapted uart class (downloadable from the Yahoo group)
I redefined it to be a char array of 256 characters. This speeds up code as it is no longer
necessary to split integers. However, the buffer size cannot exceed 256 bytes
because the JVM uses a byte for its head and tail pointers.
So your options are :
1. Get an external buffer that can hold all the bytes and that presents handshake signals to
the javelin.
2. Try baudrate 7200 (seems to be the lowest possible baud, else try 2400 or even 1200 baud)
Use a tight loop to read received characters and put them in· a userdefined character array.
The throughput of such a tight loop is about 10kbps, so 7200 baud might just work.
char buf = new char[noparse][[/noparse]5000];
for (int i=0; i< 5000; i++) { //read in data after issueing a Get Picture command
· buf[noparse][[/noparse]i] = (char)rx.receiveByte();
regards peter
This is the same person that posted this message I just forgot my groupmate was still logged in.
usually not cheap.
http://www3.sympatico.ca/photologic/fi.htm
http://www.wut.de/e-88642-ww-daus-000.php
regards peter
Post Edited (Peter Verkaik) : 1/29/2008 8:35:43 AM GMT
Also one weird question about the receieveByte() method in the Uart class. It returns an integer. Is that integer just padded in a way to where if I cast it to a char it will be just one byte of information that was sent from the camera? Or does it actually return two bytes of information from the character in one int? Is this something that's more clear if I use your modified Uart?
I found some older serial buffers on ebay and such that might do the trick. Do external serial buffers in this situation mainly just provide me a way to use the handshaking bit with the Uart class to stop and start transmission based on the amount of space left in my Uart buffer?
Sorry, I guess I included about 50 questions all in one post.
If you are using the original Uart, the receiveByte() is
·· * Receives a byte from a receive Uart. This method will block until a
·· * byte is available.
·· * @return the next byte in the receive buffer.
· public int receiveByte() {
··· int b;
··· if ( vpBank == NOT_INSTALLED ) {
····· return -1 ;
··· while ( true ) {
····· int headPointer = CPU.readRegister( vpBank|nmUartHead );
····· int tailPointer = CPU.readRegister( vpBank|nmUartTail );
····· if ( headPointer != tailPointer ) {
······· int index = tailPointer>>1;
······· if ( (tailPointer&1) == 0 )
········· b = (byte)(buffer[noparse][[/noparse]index] >>> 8);
······· else
········· b = (byte)(buffer[noparse][[/noparse]index] & 0x00ff);
······· tailPointer++;
······· CPU.writeRegister( vpBank|nmUartTail, tailPointer );
······· break;
··· // Inform the receiver so it can do the handshaking.
··· rxRead(vpBank);
··· return b;
My adapted Uart class has the following receiveByte()
·· * a byte is available.
··· int b;
··· while ((b=readByte()) == -1) ;
··· return b;
·· * This is the main receive method.
·· * Receives a byte from a receive Uart. This method returns -1
·· * if no byte is available.
·· *········ If parity is used, the byte returns with bit7 set if parity error
·· *········ -1 if buffer empty.
· public int readByte() {
··· int b; boolean error;
··· int headPointer = CPU.readRegister(vpBank|nmUartHead);
··· int tailPointer = CPU.readRegister(vpBank|nmUartTail);
··· if (headPointer == tailPointer) return -1;
··· b = buffer[noparse][[/noparse]tailPointer++]&0xff;
··· CPU.writeRegister(vpBank|nmUartTail,tailPointer);
··· rxRead(vpBank);
··· if (parity != 0) { //check for parity error
····· error = (parity == UartTools.ODD) ? !UartTools.isOddParity(b) : !UartTools.isEvenParity(b);
····· b &= 0x7F; //normally bit7 is clear when using parity
····· if (error) b |= 0x80; //set bit7 to indicate parity error
··· return b;
I redefined the buffer as a character array, so access is faster. If you comment out the parity part
of readByte() you can make it even faster.
Using an external buffer with handshake towards the javelin, lets you control the pace
at which the javelin reads data. The side of the external buffer that connects to the camera
does not use the handshake signals.
regards peter
I've found some decently cheap serial buffers that would work, but the problem is I have a limited amount of space to work with and the average size of the external buffers seems to be around 4"x5"x1".
When I bought the Javelin one of the main things that sold me on it was this line:
- 32 k bytes of RAM/program space (leftover space can be used for variables, arrays, and serial buffers
If I could avoid having to buy the external serial buffer it would make my life much easier. It really made it sound like if I wanted to I could use as much of the RAM as I wanted to as a serial buffer. Without trying to rewrite many of the core files for the javelin, is this just not going to be possible?
I guess if it's just not possible I should just start looking into a different camera module that actually has flow control available.
but, and this applies to all devices not just javelin, without flow control there
is always a problem if a device has a sustained datastream. The javelin has
256 byte driver buffers, most hardware uarts only have 16 byte buffers.
I wouldn't be surprised if your camera does have flow control but it may
just not be made external accessible.
Another camera module might be a better idea, and cheaper, than an
external serial buffer.
When using handshake, the javelin will never miss data.
regards peter
I will keep looking for other smaller and cheaper ways to solve this problem. Thanks for your advice and if you happen to think of any other way around this communication issue feel free to update me.
from 64 to 512 bytes (default is 64). If you set it to 128 bytes then you should have no loss of data,
because each packet must be acknowledged, so be sure to read all bytes before sending ACK.
This only works for compressed images (jpeg). But if you can set the compression factor to highest quality
there should be not much difference from uncompressed.
It only means you must convert to raw data in your javelin code (if you want uncompressed data).
I found this demo code in C.
http://www.electronics123.net/amazon/datasheet/C328_C_Demo.cpp
regards peter
Post Edited (Peter Verkaik) : 1/31/2008 12:08:56 PM GMT
http://www.impulseadventure.com/photo/jpeg-decoder.html
regards peter
Do you know if there is same kind of decoder code, but in Java? I'm not familiar enough with C/C++ to translate it. A camera like this one, or C628 model will help me for my color detection module.
The C328 camera can't use package mode for uncompressed files, so I will have the same issue as barichards21 regarding the buffer size. If I found a way to decompress the JPEG file, then I can do like what you suggest regarding the packages ack.
barichards21, can you share information regarding the serial buffer you found? I was not able to find any under $300 [noparse]:([/noparse]
JM
