Motors inside Servos
I had been under the wrong conception that servos contain stepper motors or other BLDCs. However this is not the case, and in fact need not be when having a gearbox with high transmission ratio..
Are there any simple indicators to judge whether a servo contains a brush motor? E.g, price? Does a brushless servo always cost more than - say - $20?
Is there a simple test without disassembling it?
Advertising details especially with bargains are not good..
I'm no expert about this but...
A complete brushless servo that accepts traditional PWM input (like in R/C model airplanes) should always cost more because there has to be a motor controller incorporated. The brushless motor itself is like a stepper it seems, permanent magnets on the rotating part and two or more electromagnets that have to be sequenced to pull the rotating part around. I guess a simple way to tell if a motor in an RC servo is brushless is to open it up and look at the number of wires going to the motor. If there are more than two wires connected to the motor, it is likely brushless as in a brushed motor only two wires are needed to drive it (not accounting for any wires that may come off a motor-integrated potentiometer to close the feedback loop of-course).
Here's a link that may be a good starting point:
http://en.wikipedia.org/wiki/Brushless_dc_motor
Regards, David
an other simple indicator, as I think: Many servo users are technic freaks. Therefore a brushless system would be named in advertisements....
Christof
Graham
http://www.hitecrcd.com/product_file/file/109/HSR-8498HB_GENERAL_SPECIFICATION_050623.pdf
cored in this case
Certainly real servo motors are often enough BL. But they do have a "somehow" bigger wattage.
If you are looking for small BL-motors, you'll find them in CD-drives.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Futuba BLS 251, 351, 451 MG
Paul Baker
OK I'll state the obvious, when they are a brushless servo they are called a brushless servo or BLS [noparse]:)[/noparse] I can't find any more other than the Futaba ones.
Graham
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
I never used motors much, and I am just trying to understand the scene. I was confused why so many people undertake the trouble to connect steppers when inexpensive servos are available. This has sorted out now!
I am disassembling PC cooler fans at the moment. Interesting things inside...
E3 = Thought
Brian
edit- Brushed motor's change there coils as they rotate by themselves.A true brushless servo is very close to a stepper motor.
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website
Post Edited (Brian Beckius) : 1/29/2008 5:12:05 AM GMT
http://forums.parallax.com/showthread.php?p=701544 Stepper Motors
http://forums.parallax.com/showthread.php?p=699165 BLDC
It depends on your application and required precision. Of course if you go to a none RC servo then it's a whole different ball game, I've some lovely Yaskawa/Omron brushless servo motors that have incredible performance.
Those fan motors have very simple drives, I think they tend to have a hall sensor integrated in the controlling IC. Of course you can also do sensor less feed back using back EMF but that's not so great at low rotation speed.
Graham
