EA DOGM128-6 Display with SPI - Page 2 — Parallax Forums
2
  • deSilvadeSilva Posts: 2,967
    edited 2008-01-27 20:40
    ' A DOGM Textreader v001
      _clkmode        = xtal1 + pll8x     ' change!
      _xinfreq        = 10_000_000        ' change!
    OBJ
      gdogm : "MPE_SPI_DOGM_005"
      font  : "dogfont_1"
    PUB main|n, addr
      gdogm.init(0)
      REPEAT
        scrollAndSetLine(string("DOGM Textreader v01 by deSilva"),30)
        REPEAT 7
           scrollAndSetLine(string("?"),0)
        waitcnt(cnt+clkfreq)
        addr := @theText
        REPEAT
          REPEAT N from 0 to 40   ' max characters
            IF byte[noparse][[/noparse]addr+N] == 13 or N == 30
               scrollAndSetLine(addr, N)
               addr += N+1
               QUIT
    PRI scrollAndSetLine(pos, bytes)| delimiter, posStr, page
        posStr := string($B0,$10,$FF,$40)
        page   := (byte[noparse][[/noparse]posStr]+1)&7
        byte[noparse][[/noparse]posStr]   := page|$B0       ' scroll through pages
        byte[noparse][[/noparse]posStr+2] := 0
        byte[noparse][[/noparse]posStr+3] := (byte[noparse][[/noparse]posStr+3]+8)&63|$40    ' scroll through pages
        gdogm.clearpage(page)
        gdogm.write(posStr, 4, 0)
        delimiter:= BYTE[noparse][[/noparse]pos+bytes]
        BYTE[noparse][[/noparse]pos+bytes] := 0
        font.aString(pos)
        BYTE[noparse][[/noparse]pos+bytes] := delimiter
        waitcnt(CNT+clkfreq/4)
    DAT
    theText BYTE
      FILE "dogfont_1.spin"
    Edit:
    Exchanged two lines!
    Post Edited (deSilva) : 1/27/2008 10:41:10 PM GMT
    edited 2008-01-27 21:02
    @Clemens: Can you please shift your last posting frim IR ti this thread?
    Hiwever, I do not understand the image write routine... You take each 8th byte only???
  • ClemensClemens Posts: 236
    edited 2008-01-27 21:44
    Yes, sorry I posted this too early and in the wrong thread. (I have removed it and will post it here as soon as it is more advanced...)
    I took every 8th byte starting from byte 1 in the 8th line, starting from byte 2 in the 7th line, starting from byte 3 in the 6th line and so on.
    So the first 8 bytes form the first column the second 8 bytes the second column and so on. (The image in the dat is thus displayed rotated by 90 degrees.)
    It worked and I thought it is smart because I don't have to switch rows after each byte.
    The text-scrolling you posted does not work on my display. It just shows half of the "v" and the "a" of "deSilva" for a second and then turns to blank.
    Did you change the "MPE_SPI_DOGM_005" since you last posted it?
    edited 2008-01-27 22:46
    Tis was extremely stupid of me... I exchanged two lines I don't know when and why...
    Corect is:
    I corrected it above.
    But during that debugging I found that you inititalize in your driver:
    $A1 and $C0 as byte 2 and 3..
    I had changed this to $A0 and $C8, and changing it with the "upsideDown" flag only inside the INIT routine, to $A1 and $C6... I must still see why it is $C6 rather than $C0...
    Nevertheless I have no strong feelings about what's upside and what's down... We should do the same though... What is the standard orientation from the manufacturer?
    edited 2008-01-27 23:36
    Now it's working! Thank You. Very Nice indeed.
    Actually wether to use it upside down or regular depends on the usage according to the manual. The angle from where I was taking the pictures is the "better" angle, the display is readable almost until you look flat across it. But I thing the overall readability is really good, so I don't mind either. But when I change the settings to upside down it cuts off the first 4 pixelcolumns and I havn't figured out why that is, yet. So much to learn. And another working day tomorrow...
    edited 2008-01-27 23:54
    I just noticed a little bug, that may not be visible on the 4-Line display. A new line is first displayed on the top line and then on the bottom line scrolling up. So the scrolling order is: "0,7,6,5,4,3,2,1" instead of "7,6,5,4,3,2,1,0"
    I didn't notice at first because I was confused by the fast scrolling, but now that I made it slower, it is obvious.
    edited 2008-01-28 00:09
    (a) I shall look into it; it in fact is "hidden" in the invisible part of my half-display smile.gif
    (b) So I shall configure your angle as normal, and turn my display smile.gif
    (c) The display has 132 columns.. Maybe only 128 are useable when writing in the backwards direction... This might explain why they advertise only 128 pixels. The smaller display is advertised as "132 pixel" and does not have such an issue.. But I shall look into it next weekend smile.gif
  • OjOj Posts: 1
    edited 2008-04-11 20:56
    Hi all,
    I've just got myself one of the DOGM128-6 displays and have been struggling to find any info on how to use it, so finding this thread is a great relief.
    The small font from Clemens looks really nice. Is there a library of a slightly larger font too? Ideally I would like to have a few sizes at my disposal in order to be able to prioritise information on screen.
    With larger fonts that run through more than one 'page' (i think this is how the rows are referred to) would it still be possible to scroll the text?
    Oj
    edited 2008-04-11 22:07
    Hi Oj,
    take a look at this thread: http://forums.parallax.com/showthread.php?p=708332
    those fonts are generated by scaling down the internal rom font, so they don't look perfect but use up little memory.
    At the moment I'm trying to learn assembler by making a driver with screen buffer for the dogm, so one can mix graphics and text.
    I am new to assembler (and programming in general) so I guess it will take a long time till I'll have something worth posting.
    I have attached another experimental version I made of DeSilva's driver that can display underlined negative bold and regular font.
    But please note that this is far from beeing optimized...
    Cheers,
    Clemens
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-04-13 13:43
    Question on backlight control (since it is seperated from the display):
    Does the DOG control the C1 and C2 (leds cathode connections) or does it need
    to be controlled externally, eg. open collector switch to GND ?
    The datasheet for the displays specifies No Connection on pins A1, C1, A2 and C2.
    regards peter
    edited 2008-04-13 14:45
    That's right, those pins are not connected to the actual Display electronically, they are just glued or melted onto the transparent plastic on top.
    So there is no command to control the backlight, you have to sacrifice another pin like you suggested.
  • RaymanRayman Posts: 15,457
    edited 2008-04-13 16:26
    That's a nice looking display... Is it only sold in Europe? I don't see it sold in the US...
    Post Edited (Rayman) : 4/14/2008 5:16:25 PM GMT
    edited 2008-04-14 16:37
    Hi Ray,
    Just got a reply to an email to Electronic Assembly, because I wanted to know when the touchscreen sticker for the display (as shown in the datasheet) will be available. I also asked if they have a US-Distributor.
    They say they are currently negotiating with Mouser and Allied Electronics. They also have a canadian distributor:
    BIRDE Marketing Inc.
    CA-Ontario
    Phone +1-905-477-7722
    Fax +1-905-477-7813
    email: toronto@birde.ca
    They didn't answer my first question though... :-( Never ask two questions in one email... :-D
    I have a very badly programmed asm driver running now. The display accepts SPI at full asm speed. - So I think it is possible to get some greyscales...
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2008-04-14 22:35
    Wonder how much it costs to ship from EU land? I find two hits, SOS has it at $21.96 and MMS-e (uk) has it at £12.99.
    http://www.mmselectronics.co.uk/lcdgraphicdog.htm
    http://www.soselectronic.com/?str=319&producer=ELECTRONIC%20ASSEMBLY
    both have the spec sheet in english.
  • richardcrichardc Posts: 6
    edited 2008-06-27 09:56
    Hi All,
    My first post to your forum, as yours is the only one I have found with any info on the practical use of the Dog displays.
    Am just building my own using the DogL 128x64 unit, using Pic assembler, - and after seeing Clemens excellent pictures - it just raised one question regarding the RST pin 39.
    He has tied it to VDD, being the condition for normal operation, however the controller manual states that after power on the RST should be held low to complete a full Hardware Reset at power on.
    Clemens display clearly works, but just wondered if any extra code was used when not doing a hardware reset ? or if in general use it has been found beneficial or necessary to do a hardware reset at power on ?
    thanks
    Richard
    edited 2008-06-27 12:36
    Hi Richard,
    You're right, if you can spare one extra pin it's a good idea to use it to do a hardware reset on startup.
    When I restart the propeller while the dogm is receiving data it sometime crashes and I have to turn the power off and on to reset it. This can be quite annoying because the dogm seems to get enough current from the usb-connection to not reset, so I have to disconnect the prop-plug too. It is only a problem while I am programming and debugging of course and no problem at runtime.
    Good luck with your project,
    Clemens
    edited 2008-06-27 14:22
    Hi Clemens
    Thanks for you quick and helpful reply.
    As you say, your way is probably fine for testing etc. - hopefully a resistor and capacitor across the RST pin will act as the power on pulse generator rather than wasting an i/o line - will give it a try, when I have the software sorted.
    Just another little point - don't know if you have seen it - the chip controller data sheet , page 54, says that you should Refresh the Dram 'regularly' but unable to find any specification as to how often that should be ?? - Do you 'refresh' the dram ?
    thanks
    Richard
    edited 2008-07-17 15:55
    Hi Clemens,
    Thought you might be interested in the link below showing my Dog unit - without using an i/o line for the Reset.
    Although coded in Pic assembler, you might be able to make use the RS glcds, particularly the Black and White one, which is very good and clear in direct sunlight.
    Richard
    http://www.electro-tech-online.com/micro-controllers/40676-glcds-pic-18f-assembler.html
    edited 2008-07-22 12:50
    Hi,
    I'm designing a DOGM128 with touchscreen into a product although I am a little confused about some minor aspects of this product. I am considering using the display in a portrait mode which should be ok I guess (software!) but I'm not sure about the viewing angle. Also, is the touchscreen available for this yet and has anybody used it? I'm trying to figure out whether the screen contacts are on the bottom of the flex etc.
    The touch-screen controller chip I'm thinking of using is the TSC2046PW which is readily available. The reason for portrait mode is it makes it easier to display a standard numeric keypad.
    Clemens,
    What is your overall impression of the display, is it good enough to use in a commercial product? Sure would help if EA had distributors here in Oz as well plus the only way to find out about price and availability is by contacting them.
    *Peter*
    edited 2008-07-22 14:44
    @ Richard:
    Conratulations for getting your driver done.
    I have a dirty but working assembler driver for the display but still a lot of cleaning up to do.
    I hope one day it will be good enough for the Object Exchange....
    @Peter:
    I havn't seen the touchpad for sale anywhere yet and Electronic Assembly seems to be interested in big business only :-(
    For my current project I used some ordinary buttons, but I plan to get another dogm (hopefully with the touch pad) soon.
    I'm very happy with the display. It is very well readable in the dark (with back light) and also in bright sunlight, which is important for me as I am using it on an automated panorama photography tripod head. I'm very satisfied with the viewing angle, but I cannot really supply any numbers in degrees.
    I was not successful in producing grayscales however. You can feed the display fast enough (full asm speed) to get a very high framerate but if you try to do grayscales by toggling pixels they won't respond fast enough and tend to be darker next to black pixels, so I guess it is just not meant to be used that way.
    It really depends on what you have in mind to judge if it is suitable for a commercial product. It cannot compete with mobile phoene displays in terms of resolution and colordepth, but it is much better readable in sunlight.
    Do you thing the touch pad could be read directly with the propeller using Sigma Delta, or is this complete nonsense? I have no understanding of how these devices work (yet).
    Post Edited (Clemens) : 7/22/2008 11:11:03 PM GMT
    edited 2008-08-03 21:06
    Hi
    Re Peter and Clemens comments about touch screens for the EA DogL units - their official stick-on touch screen for the 128 x 64 DogL is a 4 wire Analogue unit, that will require some extra hardware and software.
    However EAs 5x3-A touch screen is a 'Digital' switch type that can be fed into any micro port with just a pull up resisistor, and it will just fit onto a DogL unit with a bit of care.
    It needs a smd 10 way connector but the pins are on 1mm spacing, so can be hand soldered with a fine point bit.
    I purchased my touch screen for £8.50 net from MMSe here in the Uk, and having visited and chatted to the owner Marc, he already ships one off, small orders to diyers worldwide. http://www.mms-e.co.uk/
    hth
    Richard
    640 x 480 - 260K
    377 x 397 - 67K
    edited 2008-08-04 09:00
    hm, the datasheet of the DogL states that the "official" touchscreen behaves just like two pots for horizontal and vertical position, so I was hoping I could read it with sigma-delta.
    http://www.electronic-assembly.de/deu/pdf/grafik/dogl128-6.pdf·(Sorry, German)
    Still no way for me to find out yet because they don't sell it to unimportant people like me... smile.gif
    edited 2008-08-04 10:01
    Hi Clemens
    Quote - "Still no way for me to find out yet because they don't sell it to unimportant people like me.. "
    Assume from the time you are somewhere in the Americas ?
    Do contact Marc at MMSe here in the UK, he told me he does already export small orders to people like us - http://www.mms-e.co.uk/.
    He does stock, both the DogL 4 wire X Y Analogue screens as well as the EA 5x3 'digital switch' matrix like the one I showed / purchased.
    They are both about the same price. - make sure you purchase the matching little connector as well.
    You might find the following thread and code interesting - http://www.mikroe.com/forum/viewtopic.php?t=11953&highlight=touchscreen
    - see also Circuit Ed - glcd / touch screens for similar info.
    hth
    Richard
    edited 2008-08-04 16:50
    Hi again,
    Forgot in the previous post to attach this touch screen pfd that Marc from MMSe sent me on the general use of the 4 wire screens.
    Thats why I opted for the simpler 'digital switch' type ! - think trying to code for the 4 wire type in assember a bit beyond my abilities ! - perhaps easier for you ?
    Richard
  • spepespepe Posts: 1
    edited 2009-04-15 06:35
    Hello everybody!
    I just would liked to say: thank you for this thread! [noparse]:)[/noparse]
    I bought one of this type of LCD and had some problems making it work.
    This thread helped me a lot! So thanks to everybody who wrote anything in this thread. [noparse]:)[/noparse]
    Bye!
  • Nick DNick D Posts: 7
    edited 2009-09-23 19:17
    Guys, I understand Clemens and Desilva wrote a font for the 128x64? How do I make a font for the eadogm128x64?
    Also, could someone explain the flowchart needed to put text on one line? If I can understand the principal, I can finish the rest of it. Thanks so much for the help.
    Nick D
  • HH Posts: 21
    edited 2009-09-24 15:54
    the display is logically arranged as 128 columns * 8 pages. So the first write, starting at 0,0 of the display writes 8 rows of pixels, then increments the column address.
    Also note, it never increments the page address without sending it a command to do so, even if the column address exceeds 127.
    Since you can't read the displays memory with spi, and you'll have to shift pixels up and down 2 pages in 8bit writes, it's a bit annoying to use.
    I've attached a very basic driver I wrote, just to make the display usable for my purposes, it's a xor graphics driver, in spin, manual refresh, gobbling up 256longs of memory just to save the display state.
    The font is clemens monospace, and the spiwrite and init routine is desilvas (neat trick putting a $00 string in the dat section by the way)
    edited 2009-10-01 15:30
    I'm using the EADOGM-128x64 display. Does anyone know of a command for clearing the display? I know there's one for the 162 and 163. Right now, I'm just using the space character to clear the display, but I would think there's a better way. It takes a while to run through the Ram address by using the space character.
    Thanks.
  • HH Posts: 21
    edited 2009-10-01 16:11
    As far as I know, no clearscreen command.
    You could try the adc reverse or reset command. If I remember correctly display RAM is unaffected, so it probably won't work
    You probably end up iterating through all 8 pages, and write "0" 128 times for each page.
    desilvas driver has an example of this, take a look at the clearpage statement, and cleardogm in the dat section.
  • rubiconrubicon Posts: 2
    edited 2009-10-28 22:17
    I am in desperate need of help.... I am using the PIC 32 with the EA DOGM128-6 display with the SPI. Right now I am having trouble configuring it to the SPI. I don't know if its an SPI interface problem or an initialization problem. I will show you my code if someone here has some expereince with it. Thanks.
