Temperature Offset w/ SHT-11
I've built a simple indoor/outdoor temperature and humidity setup using two SHT-11's from Parallax. While testing it out on my desktop, I notice that the indoor sensor is starts out with approximately the same reading as the outdoor one (they are now sitting about 2 feet apart on my desk, both should see the same conditions). However, over the course of running for a few minutes, the indoor sensor starts to read increased temps relative to the outdoor one. It rises to about 5 degrees F above what the outdoor one reads and stays there.
I swapped the SHT-11 modules between the indoor and outdoor, and the same behavior was observed. I don't think it's my particular sensor. It seems like it must be something about my circuit.
Since the outdoor setup will run on batteries, I am controlling power to the outdoor SHT-11 using a Stamp pin (only supplying power when I wanted to take a reading). I implemented the same thing on the indoor setup but that changed nothing.
I changed the program on the indoor setup to ensure that the self heating element is off just to be sure. I never turned it on anyway, but this also didn't change the behavior.
Anyone else got ideas on why this is happening?
Thanks.
Greg
Thanks.
Greg
I believe the SHT-11 sensor will need a bit of time to settle. Here are some application notes on using that sensor from Dr. Tracy Allen's web site:
http://www.emesystems.com/OL2sht1x.htm
I trust there are no sources of heat where you've placed the indoor sensor, such as a desk lamp, an overhead reflector lamp in a ceiling fixture, soldering station, TV or where there is a radiator underneath it.
Bruce Bates
Veni, Vidi, Velcro! - I came, I saw, I stuck around!
Thanks for the info, there is a lot of useful information on that site.· This project is still in the breadboard stage so there is no other circuit element within a 1.5" radius.· Both the indoor and outdoor sensors are still this way.· I conducted the same experiment with all of the lights off, with the same results.
Greg
·I think once you solder everything into a board you might see more·consistant results.
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Technologically challenged individual, Please have pity.
I have a Data Logger that uses a SHT-11 sensor when you first turn the power on the SHT-11 sensor take a few minutes to settle down
mosquito56
There seems to be a problem with consistancy on a breadboard. I.E. Capacitance, Induction etc from the board itself. Also, line lengths from sensor to inputs will·cause problems.
I saw the same thing when i was play with this sensor so there is something to it
··Thanks for any·
Sam
