Extending RFID Reader Range — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2008-01-25 07:15 in General Discussion
Can I modify the Parallax RFID reader to extend the reading range from 2 inch to 3 feet?
Will a larger coil antenna do the trick?
How many turns do I need?
www.fd.com.my
www.mercedes.com.my
  • dandreaedandreae Posts: 1,375
    edited 2008-01-24 17:08
    We have been informed by the engineer who designed the RFID Reader that it is not possible to add a larger antenna or increase the detection distance to 3ft.· We were able to increase the distance from 3cm to 5cm using the card tags.
    Dave
    Dave Andreae
    Parallax Tech Support·
    edited 2008-01-24 17:09
    3 feet? I really don't think so, but maybe someone can correct me. i would think that a higher power output from the tag would be the critical feature for distance
    Shawn Lowe
    Maybe I should have waited to do that......
    edited 2008-01-24 17:11
    The RFID Reader is designed for the EM4100 Family type tags that operate at 125KHz frequency.
    Dave
    Dave Andreae
  • william chanwilliam chan Posts: 1,326
    edited 2008-01-25 07:02
    Any plans for a long range reader?
    www.fd.com.my
    www.mercedes.com.my
    You will need to use a·higher frequency system, or use an active tag.
    Here's a site which talks about the variations, higher frequencies increase the reading range, but there are drawbacks.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 1/25/2008 8:19:15 AM GMT
