camera for boe-bot
I recently purchased the boe-bot with the bluetooth adapter.
I bought a usb bluetooth adapter for my pc to comunicate with it (it says it has a range of about 300ft).
I want to be able to connect a camera to the boe-bot, view the video from my pc screen in order to remotely control the boe-bot.
Does anyone know of any bluetooth camera out there that can do this.· If such an item does not exist yet, what is the best way to go about this?
Thanks.
Thanks.
you could use a cam that transmits it's video via RF to a receiver and connect it to a TV or computer, or use a wireless IP camera. these IP cams have a web server embedded and connect to your wireless network. they work pretty well, and you can find a New but old stock camera in the neighborhood of $80.00 your mileage may vary.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Parallax sells the CMUCam... http://parallax.com/Store/Robots/RoboticAccessories/tabid/145/CategoryID/22/List/0/SortField/0/Level/a/ProductID/29/Default.aspx
Here is a great thread on using RoboRealm and a BOEbot...http://forums.parallax.com/showthread.php?p=646454
