Using a 12v battey
·I have a very expensive 12v lion battery used in r/c electric motors. I want to use this on my board which is setup for 9v.
·1. Can I connect it straight to the 5v chip?
·2. The prop runs on 3.3 v meaning the voltage is stepped down by a factor of 4. If the prop draws 100ma does that mean that 300ma is being converted to heat by the voltage regs?
·· ·I am hoping to use this in an automobile and don't want to heat up the curcuit dropping the voltages.
Thanx
BTW: I was an electronic tech. I know how to READ a schmatic but forget DRAWING one. LOL
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Technologically challenged individual, Please have pity.
Thanx
From what I understand, you have to have a 5V regulated for the BasicStamp. If the prop runs on 3.3V, I'm assuming you need a regulator that will drop the voltage to 3.3V, that will handle the 12V input. You will probably need a heatsink on the regulator to disipate that heat from dropping the voltage. Without a regulator, you will probably fry the chip or a BasicStamp.
I'm sure others that know more perticulars will answer also.
Good luck
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
- Stephen
Will I always get warm regulators?
I will check on the swithcing regulators. Thanx
Ok, it was a switching regulator: http://www.dimensionengineering.com/DE-SW050.htm
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
From a purely mathematical perspective, your statement is technically true.
But to determine the power loss, you just have to take the difference
between the regulator input voltage and the load voltage. In this case you
have 12v - 3.3 v or 8.7 volts dropped across the regulator. If you are
using a linear regulator and the load current is 100 ma, the power
lost as heat in the regulator is 0.1 * 8.7 = 0.87 watts or 870 mw.
No.
Post Edited (phil kenny) : 1/24/2008 4:18:03 PM GMT
I hope the switching regulator with a large cap might cut the heat. Power efficiency isn't a problem, just the heat and vibration.
Finally a couple guys who actually answered the question. Thanx
Have a very linear mind, it's hard to think about·Question B when Question A is unanswered.
Question B: Can I hook the 12v battery to a normal 9v system. The system has a 5v regulator and a 3.3 behind that. Would the datasheet on the regulator answer this question?
Post Edited (mosquito56) : 1/24/2008 7:03:06 PM GMT
If you're using a Parallax Protoboard or Demo Board, there's not adequate heatsinking for voltage inputs greater than 9V near the maximum current load of the regulator. If you've built your own board, you can include adequate heatsinking.
The curcuit breaker was recommended because of the old tendency for lions to catch fire. I don't think this is true anymore but better safe than sorry.
