Servo Motor Driver ( MOSFET )
I have been experimenting with replacing the guts in a servo with my own design. I have taken apart 4 or 5 servos and looked at the bridge-driver circuits used in these.· None of them use diode protection from back EMF. Now they are all micro servos and take a very small amount of current, but is this a sound design? In my own driver I would like to leave out the protection diodes since there really isn’t room for them on the board that must be stuffed into a very small case. In testing I ran it for an hour with alternating forward/reverse , stalled it for a long time etc.· Basically I tried everything I could think of to blow the mosfets, but I would rather know I’m doing an acceptable thing. Looking at the symbol for a mosfet there is a diode, is this a small protection diode?
·process.··Typically the BandGaap voltage ranges from .3V to .7V.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/18/2008 4:31:08 PM GMT
That said, you could check the datasheets for your MOSFETs to see what the current rating is for the body diodes. If they're ample enough to handle your motor's transients, it may be safe to use them that way. However, if you're looking for ironclad reassurance that omitting the external diodes is okay, you won't get it from me.
Agreed... Notice that the substrate is resistive...this makes for a 'weak' diode. Unless the diode is specifically designed into the component, then I would use an external alternative.
Beau Schwabe
IC Layout Engineer
Current rating for the body diode I am using is 8A for the P's and 7A for the N's I guess that’s plenty for these little micro motors.
Question: are transistors less prone to damage than the mosfet ( given simi equal ratings ) ?
At least two of the servos I have dissected use what I detect to be transistors. (although telling what a device is when your test lead is twice the size of a pin is quite a challenge).
