Can cogs be synchronized? — Parallax Forums
K2K2 Posts: 694
edited 2008-01-19 16:46 in Propeller 1
Can assembly language routines in each cog be synchronized so as to allow each cog to read the same external port in evenly spaced intervals?
Dave
  • deSilvadeSilva Posts: 2,967
    edited 2008-01-18 01:07
    Yes, you have to "post" some future time to all the involved COGs, so they can sync by WAITCNT to this time stamp. This is possible, because all COGS see the same CNT.
    It is also possible to do this using a "pin", waiting by WAINTPEQ...
    edited 2008-01-18 01:16
    As deSilva has said, yes it is possible. There are a few objects which have synchronized cogs, take a look at any of the vga drivers with higher resolution (1024x768, 1600x1200) to see how it can be done.
    Paul Baker
  • K2K2 Posts: 694
    edited 2008-01-18 02:23
    Excellent. Thanks be to both of you for the help.
  • pgbpsupgbpsu Posts: 460
    edited 2008-01-18 17:27
    Hi David-
    I had to get some help to do this very thing. Have a look at this thread for some code examples:
    http://forums.parallax.com/forums/default.aspx?f=25&m=231571&g=231636#m231636
    Scroll down to Ariba's first post. He makes it pretty clear how to do this. If you have questions about the code I posted, don't hesitate to ask.
    Good luck.
    p
    edited 2008-01-18 20:44
    David,
    There are several discussions on this subject... here is another example of Syncing more than one COG together on one Propeller and even Syncing more than one COG between two different Propellers together...
    http://forums.parallax.com/showthread.php?p=689451
    Beau Schwabe
    IC Layout Engineer
  • K2K2 Posts: 694
    Thank you. You've saved me many hours of grovelling!
