Ping range sensor
Today I got a new Ping Ultrasonic Sensor. The problem is that if I want to measure the range it will measure the range up to 14 cm. Normaly it detects objects up to 3 m.
My code:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Conversion constants for room temperature measurements.
CmConstant CON 2260
cmDistance VAR Word
time VAR Word
DO
PULSOUT 15, 5
PULSIN 15, 1, time
cmDistance = CmConstant ** time
DEBUG HOME, DEC3 cmDistance, " cm"
PAUSE 100
LOOP
My code:
' {$STAMP BS2}
' {$PBASIC 2.5}
CmConstant CON 2260
cmDistance VAR Word
time VAR Word
DO
PULSOUT 15, 5
PULSIN 15, 1, time
PAUSE 100
LOOP
- Stephen
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Please contact Tech Support directly to arrange to have the PING))) sent in for testing. Take care.
Chris Savage
Parallax Tech Support
