Switching ON/OFF a 3.3V Regulator with propeller — Parallax Forums
DavidMDavidM Posts: 640
edited 2008-01-23 23:41 in Propeller 1
Hi,
I need to switch a 3.3V regulator (LM2937-3.3) ON or OFF via the propeller to power a AEROCOMM RADIO MODULE ( AC4490 )
My regulator currently runs from the 5V supply of my board.
Which is more suitable, a transistor or a mosfet?
Dave M
    edited 2008-01-15 02:18
    Instead of the LM2937, use a different regulator with an enable pin. They can be found on DigiKey by choosing a package with more than three pins (e.g. TO220-5). If that's not possible, a PMOS-FET with an open collector NPN transistor, driven by the Prop pin, to pull the gate down will also work.
  • DavidMDavidM Posts: 640
    edited 2008-01-15 02:36
    Hi Phil,
    Your idea of a regulator with enable pin is a good idea, it will take up less space!
    I now just have to choose one from gazillions available!
    regards
    Dave M
  • DgswanerDgswaner Posts: 795
    edited 2008-01-15 05:19
    at least for the few regulators with an enable I looked at. the mA rating was 2-300mA Not the 1A of the LM29 series. so make sure you get one big enough to meet the "650 mA typical" requirement of the radio module.....
    "A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
    DGSwaner
    edited 2008-01-15 09:08
    I Found these two..
    LP3875ET-3.3 1.5A - NATIONAL SEMICONDUCTOR — IC, REGULATOR LDO 3.3V
    LP3964ET-3.3 — 0.8A - NATIONAL SEMICONDUCTOR — IC, REGULATOR ULTRA-LDO +3.3V
    Are these overkill, I think they are expensive!
    thanks
    Dave M
  • Nick MuellerNick Mueller Posts: 815
    edited 2008-01-15 14:52
    Bugetary price is $1.20, so you can expect a street-price of $6 for low quantities.
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
  • ohararpohararp Posts: 24
    edited 2008-01-15 18:12
    In this case I would use the FDN304P. You can switch 2.4A with this tiny sot-3 part.· I am switching 3.3V in the schematic put you can use this to source 5V without a problem.· Because this has a 1.8V gate it is no problem to drive it with a pin from the propeller running at 3.3V.· Just remember you have to pull this pin "low" for current to flow to your device.
    Datasheet:
    http://www.fairchildsemi.com/ds/FD/FDN304P.pdf
    Mouser: ($.55)
    http://www.mouser.com/Search/ProductDetail.aspx?qs=MA%2b40jw2YMpyjgZQyVD8yA==
    You can see a schematic for how I use this via the attachment:
    Ryan O'Hara
    www.ohararp.com
    Post Edited (ohararp) : 1/15/2008 6:20:39 PM GMT
    364 x 186 - 9K
  • SteveWSteveW Posts: 246
    edited 2008-01-15 20:32
    >In this case I would use the FDN304P. You can switch 2.4A with this tiny sot-3 part. I am switching 3.3V in the schematic put you can use this to source 5V without a problem. Because this has a 1.8V gate it is no problem to drive it with a pin from the propeller running at 3.3V. Just remember you have to pull this pin "low" for current to flow to your device.
    I'd be very tempted to fit a pullup resistor to the gate, though. A half-turned-on SOT23 will desolder itself fast, if your output pin is floating for a while.
    Even with the gate driven hard, I^2R losses in the FET are getting close to the thermal limits, if you're really hoping to switch the full 2.4A. Careful PCB layout would be called for.
    It would be brave indeed to switch a 5V rail with a 3.3V IO pin from a propeller straight to the gate. Even when 'off', you'll have a Vgs of 2 volts or so. That's mostly on. Expect crispy smells. A second transistor stage to get the levels, and defaults, safe would be advisable, wouldn't it?
    Steve
    edited 2008-01-15 20:41
    Or you could switch the output side of the 3.3V regulator, downstream of the filter cap. Most modern regulators have a low enough quiescent current that letting the regulator run without a load would add little to your power drain. Just be sure to use a PMOS-FET with an RDS(on) in the milliohm range at a -3.3V VGS to ensure a minimal post-regulation voltage drop.
    Post Edited (Phil Pilgrim (PhiPi)) : 1/15/2008 8:46:46 PM GMT
    edited 2008-01-15 20:47
    Yeah, that'd be safe. I'd still be tempted by an LDO with an enable pin, though, unless I was building something with some serious sales volume. I like easy...
    Steve
    edited 2008-01-16 06:15
    Hi,
    Thanks guys for all the tips,
    I think a regulator with enable pin is they way to go, As I can easily add this to my existing layout.
    regards
    Dave M.
  • mahjonggmahjongg Posts: 141
    edited 2008-01-17 12:55
    Texas instruments REG104, extremely low dropout, 1A, SOT223-5 package, and on/off input pin. REG104-A = adjustable.
  • DroneDrone Posts: 433
    edited 2008-01-17 15:25
    The REG104 is a nice part - been around for a few years & I've looked at it before. But the SOT223 lead pitch is 0.05", not 0.1". The 230mV drop out for all but the 5V part is nice (5V is 320mV), max input is 15V. These parts do not require an output capacitor. Couldn't find a unit price on the 3.3V part but the -A adjustable from Newark in unit quantity is $4.53 USD ea. (ouch!), TI budgetary 1k price for the 3.3V part is $2.35 USD (again-ouch!). For experimenters, aside from the 0.05 lead pitch is the difficulty in heat-sinking this device. Perhaps a TO220 "clip" heat sink can "capture" this device and then you can solder some leads to the pins to "break-out" to a 0.1" plug-proto-board. Hmm...
    Regards, David
    Hi,,
    I found this device FAIRCHILD KA378R33
    http://www.mouser.com/Search/ProductDetail.aspx?qs=RAZo5F3HLrnWbTu8pZ2dtA==
    Is it just a matter of connecting the enable pin to one pin on the PROPELLER , with a pulldown resistor to ground, so on start-up this regulator is OFF, and when I choose to, I ENABLE it via HI on the prop pin?
    I guess I only need 1 output CAP as usual, I will be running this from a regulated 5V device which is about 8cm away from it . So I hope I don't need a HEAT-SINK as well.
    What do you think?
    thanks
    Dave M
