Inkjet kit start up help
Hi, I am using the Parallax inkjet starter kit for a school project and feel like I am in the wrong major for this... We are trying to use the kit without the Basic Stamp microcontroller (ie, interface direct from laptop to PCB with USB cable). Has anyone done this? Chris in customer support suggested we might need to use Visual Basic to do this, does anyone have code for this? Keep in mind I'm a mechanical engineering student, so I probably won't understand what you're telling me.
Thanks in advance everyone
Andrew
Andrew
In order for the PC to control the Inkjet Printer the PC must have some software which can send the appropriate serial data to the Printer Module. You would have to create such a program to do this. We have examples for the BASIC Stamp, however these do not run on a PC.
Chris Savage
Parallax Tech Support
I am guessing Board of Education USB version will work? Is this the cheapest way to get everything I need? I am not planning on using it for anything except this inkjet application. Many thanks.
-Andrew
What are you printing ? Why do you need the PC ? It might be possible to modify the SX code of the printer driver to print. You would need to get the SX-Key or SX-Blitz to re-program the driver board.
Bean.
www.iElectronicDesigns.com
Chris Savage
