Nice Power Supply IC and other ..
Hello All,
·········· Will be incorporating this little beauty in a trial application shortly . Specs are fairly impressive.
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,P36533
I will update you all when trial is underway. Should make a nice Prop·supply .. Look at·max Vin and O/P can be adjusted down to 800mV. Nice current ratings too..·Will be suitable for Prop2 @1.8v also ..!!
While I was researching alternative components for existing controllers - I came across an alternative for the commomly available TLP521-4 Optocoupler - with pretty much identical specs. for half the price .. Just thought I'd pass on the details.. http://www.avagotech.com/products/acpl-847-000e/
·········· John Twomey
'Necessity is the mother of invention'
John Twomey
Hmm, "If you can't say something nice, don't say anything at all"
······· "No such thing as a dumb question" unless it's on the internet
········"What happens in Vegas ends up on the Internet"
Technologically challenged individual, Please have pity.
It really is a nice chip if you need the different voltages. I'm redesigning with it right now. I have a board that has two voltages needed and an automotive voltage supply. It does require a good number of passives to function to it parameters, but I think it will reduce the real estate demand on my board.
Should check on the datasheet if you get the time.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
·Depending on the "good number of passives" and the "price", I look forward to the report.
The unit price is approx US$5 .. obviously the passives are extra .. I will be using this for an industrial control board with 24v DC I/P - board incorporates an embedded WI - ethernet module which draws approx. 400mA @3.3v .. has a few hefty 5v I.C's also .. so for its size it packs a punch ! .. Overall size is neat .. its true that there are quite a few·additional passives but overall footprint should be small and for the output power capabilities and wide input voltage range it's as good as I have seen for a while ..
John Twomey
Post Edited (QuattroRS4) : 1/14/2008 9:45:44 AM GMT
That looks like a new chip.. but not easy to work with tiny..
Are you familar with the LM2575_T (5V and 3.3 V available).. series from National and other similar vendors..??
Std TO-220 type package 5 pin ..
Ron Mel oz
Efficiency for most available 3 Volt step-down converters is generally not so good (some 60%), efficiency for 1.8V converters even worse. For 5V it is some 80%.
Stabilizng with a linear regulator from a 9V battery is around 30%
That is why I (we) use 4xAA cells with nominally 4.8 Volts. That does fine for faking 5V, has 5 fold capacity of a 9V battery and also 60% efficiency
John T
Post Edited (QuattroRS4) : 1/15/2008 7:20:49 PM GMT
Post Edited (QuattroRS4) : 1/15/2008 7:21:39 PM GMT
There is much negative propagande for cadmium, sure its poisonious, but you can recycle it if you want. We have very strict laws here in Germany. It is not so obvious what to do with old NiMH cells...
Both habe memory effects when mishandled! NiCd has better price/capacity ratio, but NiMH sports higher absolute capacity (though for a much higher price!) There is a new generation of low-leakage NiHM cells for a still higher price...
As a lithium cell produces around charming 3.7 V there are some possibilities to use them too - and I do! - but the ubiquitions 1.2V AA ( or AAA) cells have unmatched advantages of handling, availability, and relative pricing. For the hobbyist there are few sitations where their generic 5.2 to 4.7 Volts cannot be used for any required nominal 5V...
