LunarX and Propeller — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2008-01-29 02:21 in Propeller 1
Chip,
·Would it be possible for you to program a RadHard FPGA to be a propeller for our lunar rover ?
www.propelX.com
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website
    edited 2008-01-12 04:56
    Brian Beckius said...
    Chip,
    www.propelX.com
    It's likely possible, but it would take too much time away from the ongoing next-Propeller effort. An FPGA implementation would be a relative power hog, I think. Is it not possible to adequately shield the current chip?
    Chip Gracey
  • Brian_BBrian_B Posts: 844
    edited 2008-01-12 05:06
    Chip,
    For $500,000 for 3 rad hard FPGA's we are trying all we can to get the propeller there.This is a ways off , but would you help with radiation testing?
    Thank's Brian
    Post Edited (Brian Beckius) : 1/12/2008 5:18:25 AM GMT
    edited 2008-01-12 22:54
    Chip,
    Brian,
    I suppose you are worried about soft errors or latch-up due to Beta, Gamma, and X radiation? I know that Alpha radiation coming from isotopes in solder balls have been known to cause soft errors in flip chips, but since all the Propellers are packaged in plastic, that shouldn't be a problem. So, Beta and up are of concern. The Propeller design was not done with radiation hardness in mind, so, like you,·I don't think it would fare especially well in a high-radiation environment.
    Here, Boeing talks about ASIC libraries they've developed which·afford some·rad-hardness using commercial IC processes:
    http://www.boeing.com/defense-space/infoelect/elecdev/radhard.html
    They also list some equipment they have which is used to test for radiation hardness. I can tell you that Parallax doesn't have those types of machines, but they advertise lab test services using them.
    We'll certainly cooperate with any needed info, samples, etc. I don't know what else we could do, for now. On that Boeing page, they mention that there are rad-hard dedicated foundries. Sounds like a lot of commitment for what is probably just a few wafers, here and there. That must be why you got that $500k price.
    Chip Gracey
    edited 2008-01-13 03:26
    Chip,
    It’s hard to get any info from anybody in the RadHard field; they just want to sell stuff. The latch-up deal seems to more a memory issue than a processor issue. If that is true we could use RadHard memory and then fire the propeller up after we get through the Van Allen radiation belt (with a little shielding).
    Thank's Brian
    edited 2008-01-28 00:20
    Chip,
    I'm working on installing the propeller on a Actel rad hard fpga, so far I think I have 2 cogs running at the same time , but have not even tried to work on the hub yet . I'll keep you posted.
    Brian
    edit- I guess I only have one cog up and running , and at very limited capacity , back to the drawing board.
    Thank's Brian
    Post Edited (Brian Beckius) : 1/28/2008 2:10:27 AM GMT
  • LawsonLawson Posts: 870
    edited 2008-01-29 02:03
    This is sounding like testing is needed. Setting up a demo on a proto-board and cooking it in high energy radiation for a while shouldn't be too costly. It's no uncommon for major Universities to have radiation sources and even experimental nuclear reactors. The University might even have a professor or two that study radiation effects on semiconductors.
    The other tid-bit I've heard is that light elements make better shielding for high-energy radiation. Stick the electronics in the center of the fuel tank?
    my 0.000002 cents
    Marty
    Lunch cures all problems! have you had lunch?
    marty,
    Thank's Brian
