SX48/52 protoboard stability
I decided to do some testing on a bad protoboard that I have. In my project I want to tap into·a battery source that supplies·unregulated 17VDC power @ .5 amp, and when on a charger it will be as high as 22VDC. I took some heat measurements, in a test run,·of the power supply, and the bad SX52 chip, the digital thermometer faulted at 158 degrees F. Now, the question is, if I were to use a good protoboard, how long would the protoboard be able to function, especially the chip itself. I could probably beef up the power supply, and the chip with some heatsinks, to reduce the heat around those areas. Has anybody done anything like this?
Ray
Ray
What voltage and current do you need from the supply ?
Bean.
www.iElectronicDesigns.com
I'm not entirely clear on how you are connecting everything to your protoboard. Are you just going to connect your 17V-22V power supply directly tot he onboard voltage regulator on the protoboard? What was heating up so hot? I can the the voltage regulator getting hot but the SX chip shouldn't get any hotter than normal unless you are trying to supply that chip directly and the regulator isn't doing it's job.
You mentioned that you are testing a bad board. Could it be that the SX chip or regulator is shorted on it and contributing to the excess heat??
Robert
Ray
