Tube Fab
I know this isn't parallax related, but I couldn't pass up posting this. A guy in france actually built his own vacuum tubes, and video taped the whole thing. It's kind of long (and in French), but still very interesting.
Hack-a-day Post
Direct to Video
-Craig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
Hack-a-day Post
Direct to Video
-Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
John Twomey
'Necessity is the mother of invention'
Some things from the video that puzzled me, that maybe someone else can shed light on:
1. What was the drum-shaped device that opened like a clamshell? He used it on several pieces of glass. Was it to dry the glass?
2. During the vacuuming-out process, he used an induction heater to heat up the electrodes. I assume this was to outgas them as much as possible before the tube was sealed?
3. Commercially-made tubes use a "getter" to bind the last molecules of gas after the tube is sealed. That's why you see a shiny deposit inside the glass wall near the top of the tube. I didn't see that here. I wonder how the lifetime of the filament is affected.
Craig, thanks for posting this. It made my day!
I really envy the fact that he makes an apparatus for just about everthing.
I'm with Phil about the "little spot welder". Very handy.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Paul Baker
I hadn't thought of annealing, but I bet that's it! Here's a Wikipedia article: en.wikipedia.org/wiki/Annealing_(glass)
There's nothing like a new idea and a warm soldering iron.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
'Anybody here have experience with one of these?
I thought you knew everything!!!
In general, these things are pretty easy to use. You simply dial in the current and time (I think there are normally two dials on decent ones), and the welder does it by itself (meaning, there is a mechanism that, once the preassure is apply, it will automatically release the current and "pinchers" after the time is up). Pretty straightforward. Location is probably one think one must consider. For instance, if what you are welding is small, you might not be able to get the pinchers (electrodes) into tight spaces. But, I could imagine that the more popular models have tons of differenct attachments to solve said problem. But at what cost???
I think we should start a "stump the guru" thread, just to find out what you guys don't know!!! [noparse]:)[/noparse] [noparse]:)[/noparse]
-Parsko
Found a DIY welder here:
The Home-Brew Spot Welder
- - - PLJack - - -
- - - PLJack - - -
This is not as easy as you think. Spot welding is almost an art. The pressure and time·are extremely critical. Once you have those set.....it works well.
Most people make the transformers from old microwave transformers (low volt/high amp)
I may come with a transformer......I just don't know.
James L
James L
Partner/Designer
Lil Brother LLC (SMT Assembly Services)
A further look leads me to believe the tips are screw in and interchangeable. Large lack of info available on this thing.
Post Edited (kelvin james) : 1/12/2008 5:42:57 PM GMT
