Anyone have code that works with 433mhz TX/RX with prop
I am playing around with the Parallax 433mhz TX/RX components with a single spinstamp. I am having a few issues getting communication happening. I have been doing a little scoping and there are voltage changes on the TX and RX lines at the appropriate times (note the TX and RX are on separate cogs). So there is definitely signal transfer between the units. I am however having trouble reading in the data with the Extended_FDSerial object. Either that or the data being sent is garbage.
Does anyone have any simple example code that they have verified works with the·Propeller and·these units? I had them working on the BS2 but cannot get them running on the Prop.
CON
_clkmode = xtal1 + pll8x
_xinfreq = 10_000_000
VAR
long stack1[noparse][[/noparse]50]
long stack2[noparse][[/noparse]50]
OBJ
Serial : "MultiCogSerialDebug"
SerialRF : "Extended_FDSerial"
SerialRX : "Extended_FDSerial"
PUB main | debugSemID, problem, local
local := clkfreq
debugSemID := locknew
problem := Serial.start(31, 30, 0, 115200, debugSemID) ' Debug via USB
SerialRF.start(4, 7, 0, 16468)
SerialRX.start(2, 6, 0, 16468)
cognew(RF_Receive, @stack1)
cognew(RF_Transmit, @stack2)
return
PRI RF_Receive | rxByte
repeat
SerialRX.rxflush
Serial.cprintf(string("waiting on data"), 0, false)
SerialRX.Rxstr(@rxByte)
Serial.cprintf(string("rec data:%s"), @rxByte, false)
return
PRI RF_Transmit | local
local := clkfreq
repeat
waitcnt(local*3 + cnt)
SerialRF.str(String("Hello World!", 13))
return
Maybe someone with a little more experience can confirm, but the main routine calls the serialX.Start routines, then terminates.
This possible leaves the two other cogs to run an uninitualized object.
Try changing the "return" command in main to "repeat", leaving it to run. This isn't efficent code, but could confirm my theory.
If it is the case, try calling the .start rountines from inside the newly started cogs.
Wait a sec...· I don't think you're allocating any actual buffer space for the string "rxByte".
Try adding a DAT section with this in it:
and remove the "|rxByte" declare from the rx routine...
Rayman, I overlooked the array creation in my post. Thanks for the tip. That said, it is not outputting any data. It is getting reads, but the Serial.cprintf(string("rec data:%s"), @rxByte, false) is outputting decimal 58 (if I use a %d in the cprintf) every single time (if using the %s it is not outputting anything). Something not right is going on as the Rxstr is triggering (which waits for data), but not populating. It does not appear like interference as it only triggers when a pulse is sent otherwise it waits indefinitely.
Any other ideas?
http://forums.parallax.com/forums/attach.aspx?a=3022
I was working on a serial circuit and found this diagram. it talks about the RF module being, in inverted mode. Could this have anything to do with it. you said that your receiving stuff but it's garbled up. every time that I've run in to the "garbled text" issue it's been a baud or timing miss match.
I'm a total spin noob, but I'll give your code a try asap.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
I'm using a lm7809 to power the proto board. and I'm also using a wallwart to power the other. I've had all of my RF modules working on LM7805's
anyone at Parallax Have a few minutes to try this out?
DGSwaner
DGSwaner
trying to receive on the propeller did nothing at all. I think I'm going to bail on these modules and keep them for my stamp projects and go with the already supported X-Bee modules.
I'm wondering if these modules are approaching end of life and that's why there isn't new code for them. IDK.
DGSwaner
Attached is an example (RF Loopback...zip) with the RF transmitter connected to P2, and the RF receiver connected to P14 through a 10 k resistor.· RF modules are powered with 5 V.· The data path goes like this:
HyperTerminal -> P31 at 57600 8N1
-> P2 -> RF transmitter -> RF Receiver -> P14 at 2400
-> P30 -> HyperTerminal at 57600 8N1
I also couldn't get it to work at 9600, and I think it's because the receiver module isn't matching the high signal times the transmitter receives from the Propeller chip. Maybe that's because of the 3.3 V vs. 5 V high signals.· Not sure yet...
Andy
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 1/9/2008 9:31:03 PM GMT
Firstly many thanks for venturing over to the thread. I am pleased to say that I have tested your code and I now have the RF units communicating.
Thanks for taking the time to test this out and provide some code. This thread can now sit as a reference for Propeller users that want to run the Parallax 433mhz TX/RX units.
One note; When using Hyperterminal (start -> run -> hypertrm) everything is just fine. When running PropTerminal the output is garbled (Possibly the Baud settings).
