Storing Data in Propeller Boot EEPROM
Bean
If I have a program that doesn't use all of the 32K program space, can I store data in the upper end of the 32K EEPROM ?
I need about 1K on the Propeller demo board.
Can I just use the last 1K ?
Does the propeller have any checksum or anthing that will get screwed up ?
Does it store the program starting at address 0 ?
Here is the code I'm trying (Uses the i2cObject)
[noparse][[/noparse]edit] I have posted working code further down...
Bean.
Cheap used 4-digit LED display with driver IC·www.hc4led.com
Low power SD Data Logger www.sddatalogger.com
SX-Video Display Modules www.sxvm.com
Stuff I'm selling on ebay http://search.ebay.com/_W0QQsassZhittconsultingQQhtZ-1
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." - David Letterman
Post Edited (Bean (Hitt Consulting)) : 12/30/2006 5:25:22 PM GMT
I2C.Init(29, 28, TRUE) ' Use Propeller Demo Board EEPROM
I2C.Start
I2C.i2cStart
I2C.i2cWrite($A0, 8)
I2C.i2cWrite(124, 8)
I2C.i2cWrite(0, 8)
I2C.i2cWrite("H", 8)
I2C.i2cWrite("E", 8)
I2C.i2cWrite("L", 8)
I2C.i2cWrite("O", 8)
I2C.i2cStop
WAITCNT(4000000 + cnt)
I2C.i2cStart
I2C.i2cWrite(0, 8)
I2C.i2cStart
I2C.i2cWrite($A1, 8)
Overlay.PutChar(I2C.i2CRead(1))
I2C.i2cStop
Bean.
Your basic concept is fine. The bootloader doesn't care what's beyond the end of your program in EEPROM. When you download a new program via the Propeller Tool and ask for it to be written to EEPROM, the whole 32K gets written and your saved data will get erased.
Your posted code doesn't wait for the data to be written to EEPROM before trying to write again. The EEPROM will not respond for about 5ms. Unless you use a paged write (depends on the EEPROM, but a 32 byte page size will usually work) to a page boundary and only one address select at the beginning of the page, then up to a page's worth of data, then a stop sequence. This will result in only one write cycle for the whole thing.
Easiest thing to do is just insert a 5ms delay after each byte written.
The program is loaded starting at EEPROM location zero and the checksum is only through the end of the program (and a few bytes beyond to the start of the stack space).
Use the "readLocation" and "writeLocation" routines in the I2C object. There's also a "writePage" routine. They do the start/address/data/stop stuff for you and are in the current version of the I2C object (1.4 or later). There's also a "devicePresent" routine that you can use instead of waiting for a write to finish. The EEPROM will appear as "present" when it's finished with the write cycle.
I downloaded version 1.3 from Parallax website. I can't seem to find 1.4 in the forums ???
Anyway, I'm still not having any luck.
I changed the code to this:
P.S. I running at 40MHz if that matters...
Bean.
I changed the i2cStart and i2cStop code and got it working partially.
Mike, can you post a link to version 1.4. I'll try that.
Bean.
I've tried the I2Cobject out. I connected a external EERPOM (24LC512) but should be the same as the 24LC256.
EEPROM adresspins A0..A2 and WP(writeprotect) are tied to GND
Port A7 = SDA (Pullup 10k to 3v3)
Port A6 = SCL (Pullup 10k to 3v3)
The Code... (using i2cObject version 1.3)
' init i2c driver
i2cObject.init(7,6,false) ' SDA=A7, SCL=A6 , (24LC512)
' write an "x" to adress 0
i2cObject.writeLocation($A0, 0, "x", 16, 8) ' $A0+i2cDeviceAdress, EEPROMadress, EEPROMdata, Adressbits, Databits
waitcnt(400_000 + cnt) 'wait 5ms @ 5MHz - this is very important !!!
' read adress 0
eepromdata:=i2cObject.readLocation($A0,0,16,8) ' $A0+i2cDeviceAdress, EEPROMadress, Adressbits, Databits
' eepromdata holds the data ("x") now
i2cDeviceAdress = 0 (A0..A2 are tied to GND, so the EEPROM device adress is 0)
- Eric
Don't know if this helps or not...
But I'm using v1.3 of the i2cObject.spin, talking to a DS1307 hanging off the same pins as the Propeller's eeprom (PINS 28 & 29). I'm using a 'Home built' demo board that has the I2C lines pulled up to +3.3VDC
So far I have not noticed any issue with the I2C driver, but like I stated I'm communicating with a RTC chip and not the Propeller's eeprom.
<EDIT>
If your using the Propeller Demo Board, it only has SDA pulled up, that might be the problem, here's a link the the Parallax Demo Board's schematic:
http://www.parallax.com/dl/docs/prod/prop/PropDemoDschem.pdf
Just an ASSUMPTION here but I think the I2C spec wants both SDA & SCL pulled up.
</EDIT>
Post Edited (Mike Cook) : 12/29/2006 8:28:01 PM GMT
rom.Init(i2cSDA, i2cSCL, false) if rom.isStarted == true txt.out($0D) txt.str(string("Started OK")) else txt.out($00) txt.str(string("Start Failed")) txt.out($0D) txt.str(string("i2c Message:")) txt.dec(rom.getError) waitcnt(5_000_000+cnt) if rom.devicePresent(EEPROM_Addr) == true txt.out($0D) txt.str(string("Selftest PASSED")) waitcnt(50_000_000+cnt) txt.out($00) outa[noparse][[/noparse]led] := low cognew(DoStuff,@stack1) cognew(DoMoreStuff,@stack2) else txt.out($00) txt.str(string("Selftest FAILED")) Pub DoStuff rom.writeLocation(EEPROM_ADDR, eepromLocation, data, 16, 8) waitcnt(50_000 + cnt) eepromlocation++Wouldn't work on the demo board due to the pullups, but works great every time with them on my custom boards(with the pullups).
you have written:
I2C.Start
instead you should try:
I2C.Init(29, 28, FALSE) ' Use Propeller Demo Board EEPROM
I2C.Start ' you don't need this
hope that work ...
- Eric
Post Edited (Catweazle) : 12/29/2006 8:41:08 PM GMT
the I2C.Init(29, 28, FALSE) works only with 10k Pullup resistor on SCL !!
At 40Mhz you need a waitcnt(200_000 + cnt)
- Eric
The attached code drives the SCL line, so don't use it for general I2C stuff. It is written specifically to read/write from/to the Propeller Boot·EEPROM.
I'm using the code to read/write from/to the last 6K (26624 thru 32767) of the 32KB EEPROM on the Propeller demo board.
Don't forget that when you save code to the Propeller EEPROM·(F11) it ALL·gets erased.
Comments welcome, (Beau?)
Bean.
Post Edited (Bean (Hitt Consulting)) : 12/30/2006 11:55:44 PM GMT
Just to clarify the earlier versions of the i2cObject did expect (following the i2c spec) that both sca/scl would be pulled up. But the current version allows you to specify when you init the object a true/false to indicate whether the scl will be pulled up.
This is explained in detail within the i2cDemo.spin & i2cObject.spin code documentation.
(Note the SDA HAS to be pulled up)
I've attached version 1.4 - its "beta" as I've been really lazy recently and haven't 100% tested it to my satisfaction.· I'll get off my backside and sort it out soon.· Version 1.4 does "page read" and "page write" on eeproms.
James
I want to write 2 numbers to storage, but I don't know what variable to pass to the write and read methods?
as I how do I work them out?
DJH
What this does is to store XXX and YYY in the EEPROM locations where they are initialized from during a reset or power on. Normally these are cleared to zero when the program is downloaded by the Propeller Tool and you've overwritten these zero values in the EEPROM. If you don't want to use these locations, you can choose any others that are not occupied by your program and its data. The easiest thing to do is to start at the end of the EEPROM ($7FF4) and work downwards since the Propeller Tool fills the EEPROM from location zero upwards. This would look like:
To read this back in you'd need to do: XXX := I2C.ReadLong(I2C#BootPin,I2C#EEPROM,$7FF4)
or YYY := I2C.ReadLong(I2C#BootPin,I2C#EEPROM,$7FF0)
Post Edited (Mike Green) : 7/4/2007 5:41:57 PM GMT
I was hoping to write to the onboard eeprom on the proto board, will that object do it? I did not think it would. (hence the reasons for beans addition?)
I guess by the look of it beans version does not support longs? just bits? So if I used that one I would have the split the long into bits?
basically I am trying to store a max speed, say for instance 17.21MPH is made up of 2 variables, 17 and 21.
Just to make my intentions clearer
Thanks for your help so far [noparse]:)[/noparse]
DJH
Bean's ReadLocation and WriteLocation routines handle single bytes only. If you want to handle words or longs, you have to do these one byte at a time.
From your description, I'm not sure how you're storing your speed value. 17.21MPH is a single value of some sort and there are all sorts of ways to store this. You could have 4 digits as ASCII characters. That still takes only one long variable (for the 4 bytes). A floating point value also takes 4 bytes. If you used a scaled fixed point value, it's still only 2 bytes (as 1721 hundreths of a mile per hour).
Thanks for the info. Do I need any pullups on the proto board?
DJH
Whether you need pullups depends on what you want to connect. The built-in stuff (and the optional I/O in the Accessory Kit) are complete as is. The EEPROM even has pullups on both the clock and data lines so it's easy to connect additional I2C devices. Do keep in mind that the Propeller is a 3.3V device and does require at least a series protective resistor (at least 220 ohm) on an input when connected to a 5V output device.
DJH
ok, Im still struggling, using the basic i2c driver I cannot see what variable I must use to put the data in, even with the example, Im kinda assuming it is the "buffer" variable?
Also to use writelong it want the device select and the address?
DJH
You do need a delay after each WriteLong. You can either copy the code in the example or use a fixed 10ms delay with "waitcnt(clkfreq/100 + cnt)".
To read the value back, you don't need a delay and you only need the first 3 parameters. The ReadLong call is a function call and it returns the value read from the EEPROM.
There are similar calls for bytes (ReadByte and WriteByte) and words (ReadWord and WriteWord). For words, the EEPROM address should be a multiple of 2. For bytes, there are no restrictions other than that you shouldn't try to store data on top of your program. If you have a Protoboard or Hydra, you can use any address from $8000-$FFFF for the Protoboard or $08000-$1FFFF for the Hydra.
As I mentioned before, you're usually safe allocating space for EEPROM data store from the end of EEPROM downwards towards the last address shown in the Propeller Tool memory map for your program.
I know I can get rid of the 2 LSB methods and just pass the function the variable, whih I will sort out next as soon as I can find out how to create random numbers within a given range to help simulate/test it.
Thanks for all your help
will go back to he drawing board
I have the code written but it is untested. I hate posting untested code, but if anyone wants to monkey with it I will (just ask).
[noparse][[/noparse]edit] Oh what the heck, here it is...
Bean.
Never argue with an idiot.· They'll drag you down to their level then beat you with experience.
www.hittconsulting.com
Post Edited (Bean (Hitt Consulting)) : 7/6/2007 5:31:45 PM GMT
Thank you
Check out my robot using the propeller RECONAUTOR
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
Post Edited (computer guy) : 1/9/2008 1:18:12 PM GMT
<http://forums.parallax.com/forums/default.aspx?f=25&m=239157>
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
