QTI problem
Hi
I´m trying to translate my bs2 QTI program to Propeller, but it won´t work. Someone have any idea what I´m doing wrong?
BS2:
Propeller:
/Hoffa
Post Edited (Hoffa) : 1/7/2008 10:30:31 AM GMT
BS2:
qtiLeft VAR Bit qtiCenter VAR Bit qtiRight VAR Bit DO HIGH 5: PAUSE 1: qtiRight = IN3: INPUT 5 HIGH 6: PAUSE 1: qtiCenter = IN3: INPUT 6 HIGH 7: PAUSE 1: qtiLeft = IN3: INPUT 7 DEBUG HOME, BIN1 qtiLeft, BIN1 qtiCenter, BIN1 qtiRight PAUSE 100 LOOP
Propeller:
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
inPin = 18
firstPin = 19
numPin = 5
OBJ
clock : "Clock"
text : "VGA_TextOut"
PUB start | i, ans
text.start
init
repeat
repeat i from 1 to numPin
outa[noparse][[/noparse]firstPin+i]~~
clock.PauseMSec(1)
ans := ina[noparse][[/noparse]firstPin]
text.printNum(ans)
clock.pausesec(1)
text.CLS
PUB init | i
dira[noparse][[/noparse]firstPin]~
dira[noparse][[/noparse]firstPin+i]~~
/Hoffa
(b) You outenable pins "FirstPin" plus 5 further.. Shouldn't that be 4 further only? Your loop in "init" looks awkward.. You know you can start it with zero, don't you?
(c) I do not know what BASIC INPUT 5 does... Can it be it sets the port to TriState? If yes, you should modify DIRA rather than OUTA for that...
Post Edited (deSilva) : 1/7/2008 8:55:31 PM GMT
I use this code:
[b]CON[/b] [b]_clkmode[/b] = [b]xtal[/b]1 + [b]pll[/b]16x [b]_xinfreq[/b] = 5_000_000 inPin = 13 firstPin = 11 numPin = 2 [b]OBJ[/b] clock : "Clock" text : "VGA_TextOut" [b]PUB[/b] start | ans, i, testPin text.start [b]dira[/b][noparse][[/noparse]inPin]~ [b]repeat[/b] [b]repeat[/b] i [b]from[/b] 0 to numPin-1 testPin := firstPin+i ans := checkPin (testPin) text.printNum(testPin) text.printStr([b]string[/b](" : ")) text.printNumln(ans) clock.pauseMsec(200) text.CLS [b]PRI[/b] checkPin (pin) : ans [b]dira[/b][noparse][[/noparse]pin]~~ [b]outa[/b][noparse][[/noparse]pin]~~ clock.PauseMSec(1) ans := [b]ina[/b][noparse][[/noparse]inPin] [b]outa[/b][noparse][[/noparse]pin]~ [b]dira[/b][noparse][[/noparse]pin]~ [b]return[/b] ansIf I try this code but with just one QTI it works fine. But when I use two they interact with each other. When one (or both) sees white both indicates 0, if both sees black both indicates 1.
