Good parts source?
Hello Guys, I have been putting together my list of parts for my getting started component box.· Do you guys know of good places to source parts?· Preferably cheap as possible such as allelectronics.· I spent about $40 there on a pending order·and I could use some more parts for sure...· I just want a good grab box so I don't have to order parts when I have ideas.· Thanks for the helps guys.
Equipped with his 5 senses, man explores the world around and calls his adventure science
-Edwin Hubble
Joe
There's nothing like a new idea and a warm soldering iron.
Greetings from Germany,
G
-Edwin Hubble
For electronic parts and·cool items check out Futurlec. They have the cheapest of any place. I also shop at Jameco and sometimes Mouser. Digikey is more expensive but they have EVERYTHING. Futurlec's selection is not as big as Jameco, Mouser or·Digikey·but if there is a specific part or IC I am looking for, I check there first and I'm usually amazed that they have it.
http://www.futurlec.com/index.shtml
http://www.futurlec.com/IntegratedCircuits.shtml
Shipping is a little bit longer but it is·only $4·- cheap prices!
I will be buying a few SX/48 protos, the SX key -related components and I put together a starting component list of about 250 parts. This should be enough to get me going...I least to last a week or so until I put out another order for more parts.
- Rick
From Jameco
black
red
yellow
white
red
green
I got these from EBay vendors:
purple
gray
blue
white/yellow
brown
orange
Wire gauge is also important for amperage. Here is what I use as a guideline
and where I get it
12 ga - 20amps (THHN used to wire up 120V outlets) Home Depot
(I buy this in spools and use it instead of zip ties
where I need to open and close the wrap frequently)
14 ga - 15 amps (THHN used to wire up 120V lights)
16 ga - 10 amps heavy gauge lamp cord, extension cords (stranded)
18 ga - 5 amps speaker wire (stranded)
20 ga - 3.3 amps heavy duty hookup wire
22 ga - 2.1 amps hookup wire (Jameco, All Elec, EBay)
24 ga - 1.3 amps Cat5E cable (Home Depot)
26 ga - 0.8 amps (haven't found a use for it yet)
28 ga - 0.5 amps ribbon cable (stranded, because it is so small you almost have to use some kind of ribbon connector) A GREAT source of this stuff is old disk drive cables (i.e. Floppy Drives, hard drives). Over the years you accumulate several as you help people fix / upgrade their computers.
Also check out these connectors that are nifty for making up quick cable assemblies between PCB's.
They connect directly to .100 spaced pins on PCB's and wires just snap in (its a little easier with a
tool but you can do it with a small screwdriver).
www.jameco.com
part# 841598
John J. Couture
San Diego Miramar College
-Edwin Hubble
http://www.sciplus.com/
http://www.herbach.com
http://www.elexp.com/
https://2298362093.monstercommercesites.com/index.asp
http://www.surplussales.com/index.html
http://www.mpja.com/
http://www.halted.com/
He who dies with the most toys wins!
Thx for the help. I will be putting in my orders within the next few days.
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
Examples:· A real time clock PCB with a DS1307 clock chip, crystal, battery and connectors all ready to plug into your system: $6.90 each!
They have some exotic parts too, such as an MP3 decoder board for $22.90.
They're pretty amazing, actually.
I'm not sure if anybody recommended Jameco at www.jameco.com , but if you're looking for wires to use on a solderless breadboard, I highly recommend their "Reinforced Jumper Wires."· These are very flexible stranded·wires with metal pins on each end which slide o-so-easily into solderless breadboards.· The typical solid wires often require long nosed pliers to insert them into the board.· These snick right in.· They're on page 201 of their catalog, which·you can download from the address above.
There·come in·three lengths:
126360 50mm/2 "· $4.45 for a pack of ten
126342 100mm/4"· $5.49 per pack of ten
126325· 200mm/8" $5.79 per ten pack.
Get three or four packs of the 50mm wires and a pack·of the 100mm·wires and all of your breadboarding will be 100% easier.
One caveat - you can't lay the wires flat along the board like you can with·solid wire and you have to be careful with your routing or your parts will be buried under all the wires.
I'd also advise you to order catalogs from lots of suppliers, especially Digi-Key and Jameco.· Online is nice, but when you're searching for a part, there's nothing like a catalog in your hands.
