Choosing a surge protection diode for a relay coil?
I'm working on a temperature controller for a reptile enclosure and need to be able to handle quite a large load. I'm going to use this relay: T9AS1D12-5 RELAY PWR SPST-NO 30A 5VDC PCB. The coil uses 5V DC. What diode should I use to protect against voltage spikes?
Typically you want to select a diode with the same or greater current rating as you are supplying the inductive load with, since it is the collapse of the magnetic field within the inductive load that you want to clamp.
Beau Schwabe
IC Layout Engineer
Also, can someone explain to me how a diode in parallel does anything anyway? It would seem that the current and voltage would take the path of least resistance and by-pass the diode completely.
http://www.kpsec.freeuk.com/components/diode.htm
In particular the paragraph from the site above probably has the answer you're looking for:
"Protection diodes for relays
Signal diodes are also used with relays to protect transistors and integrated circuits from the brief high voltage produced when the relay coil is switched off. The diagram shows how a protection diode is connected across the relay coil, note that the diode is connected 'backwards' so that it will normally NOT conduct. Conduction only occurs when the relay coil is switched off, at this moment current tries to continue flowing through the coil and it is harmlessly diverted through the diode. Without the diode no current could flow and the coil would produce a damaging high voltage 'spike' in its attempt to keep the current flowing. "
http://www.st.com/stonline/books/pdf/docs/3569.pdf
