MP3 Decoder - VS1003
Has anyone used the VS1003 MP3 decoder IC with the prop?
I am wanting to do so, and would like any advice that you can provide.
VS1003 Datasheet
Thank you
Check out my robot using the propeller RECONAUTOR
VS1003 Datasheet
Thank you
-Kit
PHRED, FIRST Team 847, Member
Go -> PHRED
Would it be possible to see pics of your setup using the vs1002?
Schematics would also be nice if you have any.
All the connections where just strait through but I am sure you could add current limiting resistors if you wanted to.
-Kit
Go -> PHRED
You'll find a lot more links if you search here search.parallax.com/ with vmusic propeller
