Brushless Motor Controller
Another recent post pointed me to the MikroKopter website (www.mikrokopter.com/ucwiki/en/BrushlessCtrl) which has some stuff about brushless motor controllers. Unfortunately I can't make much sense of it; I mean, the theory seems fine, but I have no idea how to put that into practice with the PChip as the controller.
Would anyone be willing to give me some pointers / a starting point?
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
Cheers,
Simon
Brushless controllers are not that easy from the ground up, you need fairly powerful output mosfets and the controller i.e. a uC with appropriate soft.
controlling brush less motors could be done easily with the Propeller chip! Could you post more details about the motor please.
Saluti Joerg
I had a couple of interesting links... but they are lost... I started witht the wikipedia age and some google search
This article is sort of useful:
http://www.eetasia.com/ARTICLES/2005SEP/C/2005SEP_REF_WK1.HTM
Both referenced ANs are more detailed with circuit and all, and software, well for pics. They speak of 16 kbytes of code... I thought was... simpler
have fun
Edit: In the mikrokopter page there is a brushless controller with schematic and source, and description.
Post Edited (Ale) : 1/4/2008 7:16:53 PM GMT
It is fine controler´s and motor´s on old CD player´s
Sapieha
Seems like a good place for this controller chip pdf link: http://allegromicro.com/en/Products/Part_Numbers/1442/1442.pdf
Post Edited (Fred Hawkins) : 1/5/2008 8:24:31 AM GMT
Paul Baker
With four, it is possible to rotate along the vertical axis. Two rotors (sitting on a diagonal and running CCW) run slower, the other two (running CW) run faster and then you rotate, but keep the level. They normaly do have constant pitch, so that's the only way to do it.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
motor works. I have left the influence of back EMV and other effects.
You can drive such a motor in two ways:
- driven like a stepper motor in synchronous mode. Here you have take care to not over force the
unit other ways it gets stalled.
- driven like a normal DC motor, where electronic devices are acting like the collector. The position
of the rotor has to be known! There are two way for that:
-sensing the position with sensors built in the motor (i.e. hall sensors)
-sensing the coils current and doing switching in the zero crossing moment!
I hope that helps for doing a first step
Saluti Joerg
Many thanks for all your replies. I kinda fired this off just before leaving work on Friday and should've given it more thought before doing so
Loads of info' to digest!
Thanks especially to Joerg - I really like diagrams (words aren't so easy for me to digest!).
Cheers,
Simon
