PIC DC Motor Dynamometer ? — Parallax Forums
mikefrancismikefrancis Posts: 4
edited 2008-01-04 23:03 in BASIC Stamp
Hi,
I'm a newcomer, and have the BASIC Stamp Kit. Having completed the basic exercises, I'd like to develop a practical application (in this case for model airplane development)
Here's what I want to do....... develop a "Propeller Efficiency Rig" (a.k.a a Dynamometer).
Basically, I would mount a number of different·designs of model airscrew propellors on a DC motor shaft, run the motor up through a given·RPM range, and be able to measure the following :
RPM
Current In (A)
Voltage In (V)
Power·In (WI = V X A)
Power Out (WO)
Torque (Nm) (this can probably be derived from RPM and WO)
Thrust (N) (I'll probably need to mount the motor and propeller on a low friction slider, the whole assembly in turn connected to a load cell)
Air Velocity (M/S) (I would use an anomometer for this)
During each run, I would want to collect the data for each of the above parameters say on a one-second timebase, and populate an Excel speadsheet automatically.
All ideas, suggestions, previous designs I can adapt, and the hardware options I would need, data capture software·etc·will be most welcome
Thanks !!
Mike Francis
