uOLED Clock/PLL in Demo Code
First - this thread isn't intended to start another indepth discussion about 4D Systems spec vs Propeller Datasheet regarding the clock frequency.· There are several good thread that are enlighting to read on this topic.
While I was in the US for Chirstmas I received the uOLED-96-PROP that I ordered.· I love the little packaging and the great look of the OLED.· I have liked OLEDs for sometime and love the small development platform 4D Systems has created.·
When I got the uOLED to Hong Kong I powered it up and it ran as the demo as expected.· then I wired it up to work with my Prop Plug.· I downloaded the demo code from the Parallax product page (it should be the same code that comes preloaded on the device), but when I downloaded it to the chip it didn't work.· I checked 4D Systems page to confirm Parallax was mirroring the same software and it is the same software.
After a while of experimenting and reading on the forum I tried changing the ''_CLKMODE= XTAL1 + PLL16X" to "'· _CLKMODE= XTAL1 + PLL8X" and then the code worked when downloaded.· So, again not to start another thread discussing 64 MHz. vs 128 MHz., but I am curious if this is the same experience that others who have purchased the uOLED-96-PROP have had.· If so, then I recommend to Parallax and 4D systems to adjust the demo code.
Anyone else have trouble downloading the code when the "_XINFREQ= 8_000_000" and "_CLKMODE= XTAL1 + PLL16X"?· I wish I could have the Prop running at least 80MHz. but at the moment it looks like I need to run at 64MHz.·I need to do some more reading about the PLL and clock mode.
Timothy D. Swieter
tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Timothy D. Swieter
tdswieter.com
WRT the demo code: the only explanation I have is that the demo code that comes in the ROM does not configure XTAL1+PLL16X...
Timothy D. Swieter
tdswieter.com
I completely agree with you about the 96... what a cutie pie. AND just the idea of all that power in that tiny little package is so...oh... good.
I did exactly the same thing as you...ordered it... waited forever and finally got to test it... except my demo code did run!!!
The only problem was my GPS code (based on the published smart mode) was returning regular garbage.
I don't want to start any arguments either... mostly because I really don't know anything about this issue for certain...BUT
there is a thread in this forum... don't know where... it is easy to find through the 4D corporate uoled forum... and it turns out that there is a fully documented problem on the Prop side in the serial timing... from the discussion it sounded like it is fixable but might require a major change in the structure of the serial code, which makes it a guru issue. It isn't at all clear to me that this particular problem is a hardware issue at all[noparse]:)[/noparse]
It is nice to be reminded of the physical limits of the Prop... but after reading everything, I'm not convinced that this issue has anything to do with the hardware... from either Parallax or 4D.
Don't know for sure, that's just how it sounded to me.
What is most amazing is the rapid development of these products. It sounds like the guys at 4D never sleep.
I hope they never sleep again[noparse]:)[/noparse]
Happy New Year
Rich
I think I need to reread the other threads again. Maybe I should construct a test of some sort to see if the uOLED-96-PROP is running when I download software to it at 128MHz. clock. Any thoughts from the forum on what kind of test can be written and run?
I downloaded the datasheets for the OLED controller chip. This is a similar chip to some other software I was writing a while back but never completed. I may rework the software and implement an ASM driver for the OLED.
Timothy D. Swieter
tdswieter.com
I downloaded it from 4D. But I think they are the same.
There is a complete data sheet available from Solomon?... but it is about 40000 pages long[noparse]:)[/noparse]
I'm also interested in finding a minimal hardware configuration for Femto Basic on the 96. How about a serial keyboard?
I have a feeling that Mike knows a lot more than he can say... so whatever else you do, take a look at what he has done.
Rich
I didn't answer one of your questions[noparse]:)[/noparse]
Yes absolutely it worked with and without modifications... right out of the box. I think that it might have something to do with exactly which version of the serial object you have installed... but that is just a suspicion.... of could also be ambient temperature in the room, a batch difference, etc, etc[noparse]:)[/noparse] But personally I think it is a software issue.
Rich
I brought this "issue" up and provided detail (from testing) in a previous thread. You will find lots of things that do not work if you use "_XINFREQ= 8_000_000" and "_CLKMODE= XTAL1 + PLL16X" - like IF statements!!! I use 8 & 8 for everything now when I am working with this device.
Timothy D. Swieter
tdswieter.com
Using 8MHz+PLL8x works but limits to 64MHz. To get 80MHz ( or 96MHz ) would require the fitted crystal to be replaced with another, 5MHz, 6MHz or 10MHz.
4D Systems were said to be guaranteeing 128MHz so it may be worthwhile contacting them. The obvious solution in my eyes would be for 4D Systems to fit one of the alternative crystals during manufacturing which would overcome all 128MHz operation issues and allow uOLED-96 80MHz or 96Mhz operation.
I personally will no longer attend to any discussion about this 128Mhz nonsense. Sorry Tim, no offence intended.
I agree 100%. The unit I have runs the "standard" demo just fine. The issues started surfacing (I was serious about IF statements breaking!) while I was expanding the "standard" demo code (building the Circle method) and developing an LCD driver (for PHA/Wulfden Serial card). 8MHz+PLL16x is very unpredictable. I wish I could swap out that 8MHz crystal!
One more thang... the pinouts for the uSD card appear to be incorrect in the User Manual, V1.1... Mike Green has it right in OLED_definitions.spin which can be found in uOLED96PropBasic in the Object Exchange.
cs 14
clk 15
do 16
di 17
Rich
So, what is the part number for the crystal on the uOLED and is there a 5MHz. or 6MHz. version that is the same package? Looking at the package it may not be an easy soldering job.
Away hunting I go....
Thank Rich for the revised pinout, any one confirm this?
Timothy D. Swieter
tdswieter.com
Paul Baker
I posted a sample in my thread... it has a defect in it(my programming) , but it is enough to verify the pin assignments.
I always try to connect the dots... problem is sometimes the dots aren't really connected.
This is perfect example...
I got the 96, downloaded the demo, saw that it didn't do what the demo for the 128 did in terms of writing images to the uSD card and then found that the pin-outs in the manual were wrong. I figured that there must be a reason for this coincidence. I thought "maybe there really is a problem with the product"... "possibly related to all of the hubbub in the other thread?"...
turns out: THERE IS NO PROBLEM WITH THIS PRODUCT... just plenty of room for developers to have some fun.
These uOLED's are awesome little products! Ordered another 96 last night[noparse]:)[/noparse]
Rich
I am off to the Special Olympics to watch snow shoe races in the mud[noparse]:)[/noparse] I posted some almost working uSD code over in my thread... with one simple issue that is driving me to distraction. If you have time, see what you think.
Rich
One cautious word about demos: It is the nature of a demo (demonstration of a product's capabilities) to show the product at it's best. Domos are routinely "contrived" to show the best performance possible. That is not the case with the 96-PROP demo. I wrote the demo code beleiving that the device could run at 128 MHZ and I did not encounter any problems during the writing of the code that made me think otherwise.
It might be worthwhile, for comparison, to note that just because an automibile might be advertised as being capable of going 120 MPH, that does not mean that it will be able to "corner" at 120 MPH (don't try this at home).
Likewise, even though the 96_PROP demo will reliably run at 128 MHz, doesn't mean, nor did I intend to suggest, that all code nor all projects would run at 128 MHz. That is for the user to determine (max cornering speed is something you have to determine from experience and experimentation). ;-)
Best regards,
Duffer
Since you are closer to the action, do you want to comment on the consumer changing the 8 MHz. crystal out for a 10 MHz. crystal to be able to run at 80 Mhz.? This is an after market mod of course and not supported by 4D but if you have any thoughts I would love to hear them.
Say....what else do you have cooking for your next product? I like the uOLED - it is a beautiful display and compact development platform for the Propeller.
Timothy D. Swieter
tdswieter.com
As concerns your idea of replacing the 8 MHz crystal with a 10 MHz part, it's not something I would attempt. The chances of me getting that done right with my fat fingers and old shakey hands would be about zero. I understand that some people have had a degree of success reworking and replacing parts of the size you're talking about (the crystal is one of the two largest parts on the board). I can tell you (because Atilla from 4D mentioned it in a post here some time ago) that the 96-PROP probably would have been built with a 10 MHz crystal from the beginning except for a shortage of that particular part when the boards were being built (how's that for ironic).
As for what's coming next, that's part of the reason I've been so busy lately. The new uDRIVE-uSD-G1 units are finally in full production. I have some in stock now, but haven't even had a chance to update my web site. Info at:
http://www.4dsystems.com.au/prod.php?id=22
96-PROPs and 96-G1s are finally back in stock and I've been busy with some large commercial projects involving the new 4D products.
Also, 4D has managed to locate a reliable source for the new AMOLEDs (Active Matrix OLED in sizes up to 2.8") that are just beginning to be available in quantity and in larger sizes. This has caused quite a stir among 4D's commercial customers and there has been a big push to make these available as early as Q2 this year which means a lot of custome design and programming work to make their deadlines. Especially given that most of the new, larger displays will also be available with a touchscreen option (which will also be available on their new uLCD 3.2" display available in February).
Duffer
There is no serial connection in the demo. It only requires Power and GND to run once the demo code is loaded.
Duffer
I have had one of these units since the release and I still enjoy it, however, gotta say, Duffer, that is one of the best crafted Marketing shuffles I have seen in a long time!!!
