Assembler help needed ( 64-bit negation )
hippy
Can anyone please help optimise this ( ie, fewer instructions ) ...
The two 32-bit registers make a two's complement 64-bit number accTop:accBot and if lsb of signBit is set I want to negate those 64-bits. I'm using 'invert add one' but there's got to be a better way.
There's a whole raft of NEG opcodes but I can't see any which would help me, negating accTop and negating accBot isn't quite the same as negating accTop:accBot.
shr :signBit,#1 WC, NR
IF_C xor :accTop,k_FFFF_FFFF
IF_C xor :accBot,k_FFFF_FFFF
IF_C add :accBot,#1 WC
IF_C add :accTop,#1
Shorter by one instruction and one constant if so.
Alternatively perhaps: Nuh huh
[s] test :signbit,#1 wz if_z neg :accBot,:accBot wc if_z xor :accTop,k_FFFF_FFFF if_z_and_c add :accTop,#1 [/s]Shorter by one instruction.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
Post Edited (CardboardGuru) : 12/30/2007 11:25:46 AM GMT
I tried your code, and I understand that "negating accTop and negating accBot isn't quite the same as negating accTop:accBot", but wouldn't this work?
[s] shr :signBit,#1 WC, NR negc :accTop,:accTop IF_C sub :accTop, #1 negc :accBot,:accBot[/s]·Edit - never mind, I did not take into account overflow with accBot
CardboardGuru,
I tried your code, which both versions appear to have the same end result, but I noticed that·'accTop'·gets inverted·with a "1" added to it in both circumstances.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/30/2007 7:12:42 AM GMT
Yes, bad assumption about what the carry flag would do after a neg. I was thinking it would act as a carry for the add one(neg being invert and add one). In fact it acts as a sign indicator. Silly me. Must always check.
If neg doesn't give a proper carry for the add one, then it can't be any use for multi-long negs. So explicit invert and add with carry on both longs it is, and Hippy already has the tightest version.
...Unless someone's got something really cunning...
Post Edited (CardboardGuru) : 12/30/2007 11:22:00 AM GMT
I think I might have solved it, original code ...
shr :signBit,#1 WC, NR IF_C xor :accTop,k_FFFF_FFFF IF_C xor :accBot,k_FFFF_FFFF IF_C add :accBop,#1 WC IF_C add :accTop,#1Replacing the 'invert add one' of accBot with neg and imagining there is a carry (X) that did behave as we'd like, one gets ...
shr :signBit,#1 WC, NR IF_C xor :accTop,k_FFFF_FFFF IF_C neg :accBop,:accBot WX IF_C_AND_X add :accTop,#1As neg is 'invert add one' the carry (X) we'd like to get would only be set when the resulting neg accBot == 0, thus Z is the carry bit.
shr :signBit,#1 WC, NR IF_C xor :accTop,k_FFFF_FFFF IF_C neg :accBop,:accBot WZ IF_C_AND_Z add :accTop,#1To save on the long constant, neg then sub should also work ...
shr :signBit,#1 WC, NR IF_C neg :accTop,:accTop IF_C neg :accBop,:accBot WZ IF_C_AND_NZ sub :accTop,#1I think you both got incredibly close and weren't that far off solving it yourselves. I cheated by putting a good night's sleep between then and now
My question now is ... how do I test it to destruction to prove it works ?
Eureka!
I make it 85 million days* (233 millennia) to test on one cog. You could always throw more cogs at it!
(* though I might have slipped up on the odd order of magnitude here or there.)
Post Edited (CardboardGuru) : 12/30/2007 2:41:36 PM GMT
