Assembler help needed ( 64-bit negation )
Can anyone please help optimise this ( ie, fewer instructions ) ...
The two 32-bit registers make a two's complement 64-bit number accTop:accBot and if lsb of signBit is set I want to negate those 64-bits. I'm using 'invert add one' but there's got to be a better way.
There's a whole raft of NEG opcodes but I can't see any which would help me, negating accTop and negating accBot isn't quite the same as negating accTop:accBot.
shr :signBit,#1 WC, NR IF_C xor :accTop,k_FFFF_FFFF IF_C xor :accBot,k_FFFF_FFFF IF_C add :accBot,#1 WC IF_C add :accTop,#1
Shorter by one instruction and one constant if so.
Alternatively perhaps: Nuh huh
Shorter by one instruction.
Help to build the Propeller wiki - propeller.wikispaces.com
Play Defender - Propeller version of the classic game
Prop Room Robotics - my web store for Roomba spare parts in the UK
Post Edited (CardboardGuru) : 12/30/2007 11:25:46 AM GMT
I tried your code, and I understand that "negating accTop and negating accBot isn't quite the same as negating accTop:accBot", but wouldn't this work?
·Edit - never mind, I did not take into account overflow with accBot
CardboardGuru,
I tried your code, which both versions appear to have the same end result, but I noticed that·'accTop'·gets inverted·with a "1" added to it in both circumstances.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/30/2007 7:12:42 AM GMT
Yes, bad assumption about what the carry flag would do after a neg. I was thinking it would act as a carry for the add one(neg being invert and add one). In fact it acts as a sign indicator. Silly me. Must always check.
If neg doesn't give a proper carry for the add one, then it can't be any use for multi-long negs. So explicit invert and add with carry on both longs it is, and Hippy already has the tightest version.
...Unless someone's got something really cunning...
Post Edited (CardboardGuru) : 12/30/2007 11:22:00 AM GMT
I think I might have solved it, original code ...
Replacing the 'invert add one' of accBot with neg and imagining there is a carry (X) that did behave as we'd like, one gets ...
As neg is 'invert add one' the carry (X) we'd like to get would only be set when the resulting neg accBot == 0, thus Z is the carry bit.
To save on the long constant, neg then sub should also work ...
I think you both got incredibly close and weren't that far off solving it yourselves. I cheated by putting a good night's sleep between then and now
My question now is ... how do I test it to destruction to prove it works ?
Eureka!
I make it 85 million days* (233 millennia) to test on one cog. You could always throw more cogs at it!
(* though I might have slipped up on the odd order of magnitude here or there.)
Post Edited (CardboardGuru) : 12/30/2007 2:41:36 PM GMT
