Suggestion: sizeof(<Identifier>) for Spin — Parallax Forums
Nick MuellerNick Mueller Posts: 815
edited 2007-12-29 01:07 in Propeller 1
Hi!
I know it doesn't exist, so my request.
A sizeof($someIdentifier) for Spin would be very handy.
Say one wants to save a variable to EEPROM, knowing the size would help a lot. I could calculate it by hand, but then I do have a maintenance-problem (when my code changes). I also could arrange all vars in a sequence and put a sentinel behind the last one and use the difference in addresses to calculate the size, but then again: What when the code changes? What if I don't want to change the sequence? What if one var gets bigger and the other one smaller? What if for some reason the vars do get a new layout in RAM because of a new compiler version?
Other scenarios would be passing an array of varying length to a generic function (like build the average over a list of values).
The sizeof operator should return the size in bytes. Making it a compile-time-only feature is enough. sizeof should be able to handle this correctly:
VAR
  long SomeArray[noparse][[/noparse] 10 ]
  sizeof(SomeArray)       'returns 40
  sizeof(SomeArray[noparse][[/noparse] 0 ]) 'returns 4
The compiler does know the sizes, because he does make a layout for the RAM.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
  • CardboardGuruCardboardGuru Posts: 443
    edited 2007-12-27 10:41
    Nick Mueller said...
    CON
        SomeArraySize = 10
        LongSize = 4
    VAR
        LONG SomeArray[noparse][[/noparse]SomeArraySize]
        constant(SomeArraySize*LongSize) 'returns 40
        longsize ' returns 4
    Help to build the Propeller wiki - propeller.wikispaces.com
    Play Defender - Propeller version of the classic game
    Prop Room Robotics - my web store for Roomba spare parts in the UK
  • deSilvadeSilva Posts: 2,967
    edited 2007-12-27 10:58
    Nick,
    you have still the most fantastic ideas of how SPIN handles "DATA". SPIN does not handle "DATA". There is no such thing as an "ARRAY"....
    SPN is a "structured assemply language"
  • DroneDrone Posts: 433
    edited 2007-12-27 11:32
    One might argue the way Spin accommodates strings constitutes support for array data structures:
    Paraphrasing the Wikipedia entry for "Array": In Computer Science an array is a "data structure" consisting of a group of "elements" that are accessed by "indexing". In most programming languages each element has the same "data type" and the array occupies a contiguous area of storage. Most programming languages have a built-in array data type. Paraphrasing Wikipedia...
    So, we have a zero terminated string made with:
    string("123456)
    . The data in the string is cf the same data type and occupies a contiguous area of storage. The string (arguably an array) is accessed by "indexing" with perhaps:
    byte[noparse][[/noparse]index]
    . To help in knowing the total array size when indexing the data within the array, Spin includes the likes of:
    (strsize(@stringaddress))
    , where @stringaddress is the pointer to the location of the "array" in storage.
    Hmmm...
  • Nick MuellerNick Mueller Posts: 815
    edited 2007-12-27 11:47
    Exactly this does *not* solve the maintenance problem.
    With your background, you should know what that means.
    Make a change in one place and *only* in one place. Your suggestion requires changes in at least two places. -> maintenance problem.
    It's getting really funny with constructs like:
    CON
      AdvGridSize = 3
    VAR
      long AdvGrid[noparse][[/noparse] (AdvGridSize + 1) * (AdvGridSize + 1)]
    Oh my god! Spin does not reserve memory for a construct like "long someArray[noparse][[/noparse] 10 ]" and it does not handle indices?
    I *REALLY* must have missed something.
    Further I don't care -in this case- how Spind handles VARs, I only request a sizeof operator and I am 100% sure it could do it.
    Maybe you only missed the "compile-time"?
    Have a closer look:
    a) "long someVar[noparse][[/noparse] 10 ]" reserves 10 longs in HUB-RAM
    b) x:= someVar[noparse][[/noparse] 3 ] is aware of the type (the long), or the index would be wrong (byte? word?, long?)
    c) even if someVar[noparse][[/noparse] $index ] is handled like a pointer, still b) is true
    d) try a "long someHugeArray[noparse][[/noparse] 1000000 ]" to see that Spin *is* aware of how much memory the declaration consumes
    e) I'll have to tear out several pages of the Propeller-Manual containing the word "array"
    Nick
    YADRO
    edited 2007-12-27 11:53
    This only works for strings, because they are zero-terminated. It is a runtime-computation and not done at compile-time.
    strsize is not aware of the length @stringaddress points to. Don't know a language that would do that for a *pointer*. And also wouldn't ask for it.
    Nick
    YADRO
    edited 2007-12-27 12:06
    1) Yes it does.
    2) Yes I do, thanks.
    3) Yes. Set one value in only one place.
    4) No it does not.
    ...[noparse][[/noparse]something I did not suggest]
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2007-12-27 12:09
    I am in favour of sizeof() also (waiting for imagecraft)
    Possible workaround,
    When you define a variable (may be an array) with name VARNAME,
    then also define a constant with the name sizeofVARNAME.
    (place the constant directly above the variable)
    CON
    · sizeofVARNAME = 40
    VAR
    · word VARNAME[noparse][[/noparse]20]
    where you would like to use sizeof(VARNAME), use sizeofVARNAME
    regards peter
    edited 2007-12-27 12:15
    > 1) Yes it does.
    It does not (see below)
    And what if you change it from long to word?
    > 4) No it does not.
    It does. See above
    Well, you didn't suggest it, but it is part of the problem where a sizeof is the only help.
    Nick
    YADRO
    edited 2007-12-27 12:25
    Yes, that does work, but only if I manually keep track of changes. That's exactly what I do *not* want to do.
    This partly relates to "magic numbers"
    I'm using (I'm not alone) constructs like:
    CON
      cCPRMask = %111
      cCPR = CPRMask + 1
    VAR
      long CPRTicks[noparse][[/noparse] cCPR ]
    So avoiding "magic numbers" and keeping the paradigm to make a change only in one place and not in three.
    Nick
    YADRO
    edited 2007-12-27 12:51
    If someone is interested I can recommend some elementary textbooks about compiler construction, data types etc., etc. I can't help when someone writes things into wikipedia that do not match exactly the modern idea of data types, and is biasedly interpreted.
    Sometimes it does not matter to not distinguish between the basic concept of contiguous cells of a linearly addressed memory and an "array"; sometimes - as with SPIN - it gives rise to the most phantastic ideas of what "should" work, or how it "should" work.
    Post Edited (deSilva) : 12/27/2007 12:56:17 PM GMT
    edited 2007-12-27 12:55
    That's why there are two constants. I named the second one LongSize because the scenario you set up was an abstract one. But that constant is the size of the elements of the array. Whatever you call it, you change it from 4 to 2. As I said, one change.
    However, if you changed the elements of the array from long to word, you'd have bigger considerations than that, given that LONG is a signed integer and WORD isn't.
    Peter Verkaik said...
    It wouldn't do any harm for it to be there, but it's unlikely to be worth the changes to the compiler necessary to implement it. It's unlikely that the compiler retains the length of the array declaration part the point at which is compiles that statement. Implementing sizeof would require an extra column in the symbol table, and that's far from a trivial change, particularly is the compiler is really written in X86 assembler.
    The fact is it's needed for C for three reasons:
    • Because different implementations of C have different sizes of fundamental types.
    • Because different implementations have different rules for padding.
    • Because C has structures.
    None of these apply to Spin. Defining your data sizes with constants up front is all that is required to do any sizeof task. Sizeof is superfluous to Spin.
    edited 2007-12-27 12:59
    deSilva, don't get disheartened, you're absolutely right. Despite any impressions to the contrary in the manual, it's pretty obvious Spin does not have an array type. It has an LONG/BYTE/WORD declaration syntax that optionall allows creating extra space in variable memory. And it has an indexing operator that can be applied to any variable.
    edited 2007-12-27 14:19
    Two constants, two places to make a change. First in the declaration, second in the constants.
    <content deleted by moderator for violation of forum guidelines>
    Nick
    Post Edited By Moderator (Paul Baker (Parallax)) : 12/28/2007 6:12:47 PM GMT
  • hippyhippy Posts: 1,981
    edited 2007-12-27 17:45
    CardboardGuru said...
    It shouldn't be that hard to do, and I just added and tested a SizeOf function in one of my own compilers ( written in VB6 ) in just a few minutes to see how hard it was to do. Whether it's worth it should be measured by user necessity IMO not how difficult anyone made it for themselves through their choice of programming languages. I'd be a bit concerned if someone came up with a solution which was not easily extendible as that also implies to a degree not easy to fix or maintain. I expect Parallax wouldn't have a major problem implementing it if they chose to.
    You can kludge together a runtime version which will return the base size of the variable or array but as there's no knowledge of an array's length at runtime that isn't as easy ...
    CON
      _CLKMODE      = XTAL1 + PLL16x
      _XINFREQ      = 5_000_000
    OBJ
      tv            : "TV_Text"
    CON
      TV_PIN        = 12
    VAR ' The magic marker variables ( in any long, word or byte order )
      long longMarker
      word wordMarker
      byte byteMarker
    VAR ' User declared variables ( in any long, word or byte order )
      byte aByte
      word aWord
      long aLong
      long aLongArray[noparse][[/noparse] 10 ]
      word aWordArray[noparse][[/noparse] 10 ]
      byte aByteArray[noparse][[/noparse] 10 ]
    PUB Main
      tv.Start( TV_PIN )
      ShowBaseSizeOf( String("aLong           "), @aLong           )
      ShowBaseSizeOf( String("aWord           "), @aWord           )
      ShowBaseSizeOf( String("aByte           "), @aByte           )
      ShowBaseSizeOf( String("aLongArray      "), @aLongArray      )
      ShowBaseSizeOf( String("aWordArray      "), @aWordArray      )
      ShowBaseSizeOf( String("aByteArray      "), @aByteArray      )
      ShowBaseSizeOf( String("aLongArray[noparse][[/noparse] 1 ] "), @aLongArray[noparse][[/noparse] 1 ] )
      ShowBaseSizeOf( String("aWordArray[noparse][[/noparse] 2 ] "), @aWordArray[noparse][[/noparse] 2 ] )
      ShowBaseSizeOf( String("aByteArray[noparse][[/noparse] 3 ] "), @aByteArray[noparse][[/noparse] 3 ] )
    PRI ShowBaseSizeOf( strPtr, varPtr )
      tv.str( strPtr )
      tv.out( " " )
      tv.dec( BaseSizeOf( varPtr ) )
      case BaseSizeOf( varPtr )
        1 : tv.str( String(" Byte") )
        2 : tv.str( String(" Word") )
        4 : tv.str( String(" Long") )
      tv.out( $0D )
    PRI BaseSizeOf( varPtr )
      if varPtr => @byteMarker
        result := 1
      else
        if varPtr => @wordMarker
          result := 2
        else
          result := 4
    edited 2007-12-27 18:42
    Cheers guys!
    (literally)
    Seems to me, the time and energy spent grappling with getting SPIN to conform to other language constructs, is far better spent just simple understanding of how it works, then leveraging that.
    It also seems to me, regularity and predictability, are two elements necessary for longer term sanity; therefore, kludging an operating environment, to behave in a fashion outside it's scope of intent, then differentiates ones efforts in a way that violates these two ideas, even though that may well be the intent! Having done this, one's body of code is then more difficult to merge and or leverage with other bodies of code, written with the language intent in mind. It's a net loss all around.
    Understanding exactly how something works is half the problem. (IMHO, the more critical half) Realizing best case efforts, knowing that, is the other half.
    For those, invested in specific means and methods, the effort of mapping one onto the other can often, at first glance, appear to be time well spent, as this leverages existing understanding and practice. However, doing this without full consideration for those things that differentiate a given platform (and I'm gonna label the Propeller as a platform --loosely for this expression), is highly likely to then marginalize the differentiators that made said platform worth realizing in the first place!
    It's a Propeller! And it's significantly different from most other CPU's, and those differences have distinct advantages. (IMHO, that's exactly where the fun is!) There are some constraints in play, different from most other CPU's, that impact SPIN. Those same differences yield significant benefit at the same time. This mapping process is not as likely to pay off compared to other CPU's, largely because the Propeller just isn't like other CPU's, and that's the core of it right there.
    Consider both, or consider none. Anything else is a complete waste of time and one will find it to be nothing more than an exercise in frustration at this time.
    For what it's worth, this Propeller will see Large Memory Model C code very soon, which will somewhat marginalize it's overall utility (failure to realize full speed potential), but will at the same time, largely eliminate many of these discussions. Prop II, will reach a point in scale, where those differences, for a very large scope of applicable tasks, become adademic. (still some speed loss, but overall speed possible falls well within the scope required for many tasks)
    Software driven design lies at the core of what the Propeller is supposed to be. That means everyone involved has the maximum amount of choice as to how to best apply the hardware. It also means some time to build the code elements necessary for greater numbers of people to get along. Finally, it means often being able to realize some specific functionality, with a minimum of additional hardware required, and that only promotes greater overall utility in general. The cost for that (and one just can't have everything) is some significant differentiation in how things are done at the silicon level. That has what should be obvious code implications.
    The other elements of the Propeller are symmetry and determinism. Being able to re-purpose both hardware and software at the COG level, means some core changes in the chain of tools one uses to construct larger projects.
    There is some learning that's gonna have to happen in order to take best advantage of these core things.
    Bending SPIN into something other than what it is today, makes zero sense, given the above and some time passing.
    Right now, at this point in time, SPIN is an entity as unique as the chip is! It is that way for a reason; namely, to make exploiting the advantages presented by the Propeller, more accessible to more people, easier than would otherwise be the case with assembly code alone. In this vein, SPIN hits the mark perfectly, and does it in a mere ~500 instruction words too boot! Combine it with assembly code, and the multi-processing elements of the chip, and you get something that has a very wide range of applicability. That was the target for the chip, it remains it's primary differentiator at this time, and through the next iteration of the core design.
    Coming here, and (expletive)ing about, the cost of this applicability, in the form of non-compliance with other established means and methods, is just not productive for anyone involved.
    Again, it's a Propeller. Go and look at the data sheet and consider what that means, then think about what SPIN does do, and leverage that accordingly, or wait for others to build middle ground tools. It won't be all that long.
    Post Edited (potatohead) : 12/27/2007 6:49:40 PM GMT
    edited 2007-12-27 18:48
    <G> I fail!
    > You can kludge together a runtime version which will return the base size of the variable or array ...
    That's a clever trick!
    > ... but as there's no knowledge of an array's length at runtime that isn't as easy ...
    Well, at least you demonstrated how "complicated" it is to collect the data for a sizeof. I knew that before, but ... well ... there are better gurus than you and me.
    Nick
    YADRO
    edited 2007-12-27 19:28
    Spin has a mechanism to allocate space for variables, and it also has a mechanism to access elements indexed from the beginning of an allocated space. But there's nothing in Spin that enforces bounds on that access. Consequently, it would be hard to say that a so-called "array" has any "size" at all.
    If Spin supported dynamic arrays or did automatic bounds checking, then a sizeof function would be mandatory. In its present state, however, "arrays" have no real bounds, so a sizeof function could be misleading to the casual programmer. But aside from that, the suggestion seems rather harmless and could even be useful in certain circumstances. Personally, though, I would continue to allocate space using a defined constant, a la CardboardGuru's example, and use that constant in lieu of sizeof.
    edited 2007-12-27 19:52
    Phil,
    Ditto. I use named constants or simple constant expressions (x+1 or x-1) based on them for most array and loop bounds. Works great!
    edited 2007-12-27 20:37
    hippy said...
    Well "should be" is neither here nor there. "Is" is what's being dealt with, and if it's true that the compiler is written in hand crafted X86 assembler, then it's true that changing the structure of a something as central as the symbol table is likely to be a major undertaking. This isn't a hobby compiler, but a released one that people rely on, so the extra functionality (minimal) needs weighing against the possibility of introducing new defects (significant). And that within the known situation that the compiler is a maintained by one person who usually has other priorities above adding new features. New features are going to be for things that are not possible already, not this.
    hippy said...
    Well, that part of the problem wouldn't be at all hard to add to the compiler anyway. The Symbol table must already notes the "base size" of a symbol to enable indexing etc. As you say, the "array size" is probably unknown beyond the moment is takes for the compiler to reserve the variable space for it.
    Phil, Mike,
    Indeed, it's hard to see how declaring a constant for the arraysize and then declaring the array from that variable is not perfectly adequate for the task. Good practive is to do that anyway.
    Post Edited (CardboardGuru) : 12/29/2007 2:08:28 AM GMT
    edited 2007-12-27 21:05
    hippy said...
    I could counter with "likely to be" is equally neither here nor there, that it would just be another field to add to the symbol table ( or the size can be derived by ascertaining the difference between its base address and the next allocated ) ... but there's enough (pointless) argument going on in this thread as there is.
    Just because it's written in assembler doesn't mean it is a major undertaking to change things, but that does depend on how well written the code is and what consequences changing a core data structure has - ironically, a possible issue of SizeOf() itself smile.gif
    Mine's not a hobby compiler either and I don't see any significant risk of adding new defects unless the compiler is poorly designed. For mine it involved three changes; adding a field to the symbol table, setting that field when an array is defined ( zeroed if not an array ) and creating a factor function to handle SizeOf. No interactions there with any other existing code.
    edited 2007-12-28 18:04
    It has been brought to my attention that some posts in this thread are in violation of our·forum guidelines ( http://forums.parallax.com/showthread.php?p=467912·) specifically #5.·I have deleted or modified those posts which contained personal attacks.·Arguements are not permitted to reach the level of personal critisisms, please refrain from doing this in the future.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 12/28/2007 6:41:41 PM GMT
  • terrymrterrymr Posts: 19
    edited 2007-12-28 18:37
    There's no arrays in C either ... an array is simply a pointer and the index is just added to that pointer. The only problem with this is that things like bounds checking and such are left to the programmer.
    edited 2007-12-28 19:30
    With very few exceptions, there is a significant cost associated with things like run-time bounds checking and, although there have been hardware solutions in the past, there really are none now, particularly in embedded systems / microcontrollers where the hardware cost would be significant in relationship to the rest of the hardware. The best solutions (in my opinion, based on a lot of experience) are more strongly typed languages like Pascal, but with explicit "loopholes" that allow you to override the strong typing when necessary, while still keeping it as the default. A very nice implementation is Palm Pascal which compiles for both the 68000 and ARM and is free. You can write all kinds of Palm OS system calls using the language and typing rules, yet have essentially untyped pointers where the OS requires it.
    edited 2007-12-28 23:36
    > It has been brought to my attention that some posts in this thread are in violation of our forum guidelines
    You for got to delete something, in your desperate attempt to keep the PC in this forum.
    Search for "stupid"
    Nick
    YADRO
  • Mike_GTNMike_GTN Posts: 106
    edited 2007-12-29 00:12
    Hi Nick,
    I did complain about some of the Anglo Saxon Language you decided to use. It is a total shame when 10 year old kids read this type of stuff.
    This happened to me. Life has rules, when I disagree with people I tend to just walk away. When I have nothing good to say then I tend to remain silent.
    I know not helping now in this situation, what is the expression "Don't feed the trolls"
    I believe that Paul took the correct action in this instance, he then also spent his time and created a new thread that laid things out in very simple terms.
    With Regards
    Mike.
    Ok, now I see what you are talking about, and I have removed that as well. But everything I told you in the PM still stands, because that post was in response to your earlier inflamatory posts. You have a problem with someone, come to me and I will do my best to resolve it, do not under any circumstance escalate the situation by responding to·a post when you are mad.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 12/29/2007 3:01:57 AM GMT
