Hot regulator
Any comments on why my 3.3v reg on my board is getting quite hot to the touch?· Is this quite normal for sot-223 to run hot?· The prop is cool to the touch.· I am posting my schematic for reference.· The 8.0v dpk also runs quite warm also. I estimate the temp to be 140F+
I'm pretty sure the current drawn was at least 300-500ma. With a 9V input, that's 2W dissipation in the 5V regulator and maybe 1/2W in the 3.3V regulator. On the Protoboard, the regulators are cascaded. In your case, you've got a 4V drop across the 8V regulator, then a 3V drop across the 5V regulator and a 4.7V drop across the 3.3V regulator. All of that has to be dissipated as heat based on the current load on each regulator. You will either need to heatsink them or use a switching regulator instead.
Post Edited (Mike Green) : 12/22/2007 4:56:44 PM GMT
Don't get confused from the large current values in the datasheet; they are ALWAYS meant with appropriate cooling and minimal drop-down
Maybe you should put the 3.3V regulator downstream of the 5V so it doesn't have to drop so much voltage... At a minimum, the regulators must dissipate power equal to their voltage drop times output current...
If you are really drawing a lot of current at 3.3V, you will have to attach a heat sink to the regulator (or switch to a switch mode DC-DC converter, which is more efficient).
But, you have to worry about electrically insulating the tab too... I like the NJM regulators that have an epoxy covered tab. With those, you don't have to worry about electrical isolation...
Post Edited (Rayman) : 12/22/2007 6:16:08 PM GMT
Think about this.· If you make two heatsinks out of thermocouple material,·connect them in series and push current thru them, you·should see the first heatsink in series have a net·heat flux out, and the second should see a net heat flux in, in order to·conserve power.··You are cooling one of the·2 thermocouples with current alone.·Negative thermal resistance , like how evaporative cooling sometimes exhibits, No coolant, no moving parts.· Theres alot you can do with this, not many people know that this exists.·
Honestly tho if you arent making something hyper precise, the small bit of efficiency you get out of designing the heat sink is not really worth it. Go get a charge pump boost regulator from TI (TPS61081), will do up to 50 v @50 mA all the way to 3.3V, only one external inductor and super small.· Those linear regulators are terribly inefficient compared to the switching charge pumps, which can get to almost 93% efficient or so I believe.·
kevin
You'll have to answer that yourself based on your information about current drain, voltage drops, thermal resistance, etc. This is all Ohms law, the definition of power (Watts = Volts * Amps), and the equivalent of Ohms law for heat. Nothing really complicated.
dissipates 0.4W for dc input voltages up to 34V.
http://www.recom-international.com/switching_regulator_R-78xx.html
They are as easy to use as a 7805 regulator. Why bother with heatsinks at all?
regards peter
Some months ago you had only the choice between some additional caps and inductors (5 additional parts) or inductor-less tiny SMD devices providing between 50 and 100 mA.
But I couldn't find a price tag for the R-78XX
Should be something around 10.- .. 15.- EUR or such.
A DC/DC 5V/5V converter costs 7.- EUR
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
though I think they also have·industrial sales.
The ordernumbers are
154495 (3.3V 1A) SIP3
154496 (5.0V 1A) SIP3
154481 (3.3V 0.5A) SIP3
154483 (5.0V 0.5A) SIP 3
http://www1.int.conrad.com/scripts/wgate/zcop_in/~flN0YXRlPTExMzI2MzAyNTY=?~template=PCAT_AREA_S_BROWSE&glb_user_js=Y&shop=A_B2C_IN&p_init_ipc=X&~cookies=1
Edit: here is the pricetag page from Recom
http://www.recom-power.com/pages/highseller.php
regards peter
Post Edited (Peter Verkaik) : 12/25/2007 10:41:20 AM GMT
Edit: RECOM (according to the links) sells for $10.82 (3.3V @ 500mA) and $9,75 (5.0 V @ 500mA; there is also a 1A type of unclear price..)) +VAT of course
Edit2: CONRAD takes 9,28 € for the 500mA and 10,16 € for the 1A types (incl. VAT)
Post Edited (deSilva) : 12/25/2007 11:03:44 AM GMT
and they're almost the exact same size as a TO-220. For 15 bucks (plus 1.25 for shipping) You get 1 amp at any voltage between 1.25 and 10.
NO extra parts needed.
