What am I doing wrong?
Frustrated beyond believe!
Hunger hurts, starvation works!
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
gpsTx = 21
gpsRx = 20
gpsBaud = 4800
'GPS Commands
GetInfo = $00
GetValid = $01
GetSats = $02
GetTime = $03
GetDate = $04
GetLat = $05
GetLong = $06
GetAlt = $07
GetSpeed = $08
GetHead = $09
VAR
byte info[noparse][[/noparse]2], valid[noparse][[/noparse]1], sats[noparse][[/noparse]1], time[noparse][[/noparse]3], date[noparse][[/noparse]3]
word heading[noparse][[/noparse]2], speed[noparse][[/noparse]2], alt[noparse][[/noparse]2], lat[noparse][[/noparse]5], lon[noparse][[/noparse]5]
OBJ
uart : "Simple_Serial"
debug : "FullDuplexSerial"
PUB Delay(mS)
waitcnt((clkfreq / 1000 * mS) + cnt)
PUB main
debug.start(31, 30, 0, 19200)
waitcnt (1_000_000 * 25 + cnt )
uart.start(gpsRx, gpsTx, gpsBaud)
repeat
uart.tx(String("!GPS"))
uart.tx(GetInfo)
info := uart.rx
debug.str(@info)
debug.str(13)
debug.str(10)
SimpleSerial does not buffer any bytes, so you will generally miss data when using speeds above - say - 300 baud.
You generally use .rx in a tight loop (you have around 5 to 10 simple SPIN lines during the 9600 baud stop-bit time slot - no calling routines or such!)
You can also use a separate COG for that loop.
In that situation however you should use "FullDuplex", which does exactly that. FullDuplex can be instantiated multiple times.
Edit: Are you really sure, the GPS commands are binary? Would be strange...
Post Edited (deSilva) : 12/25/2007 9:31:20 AM GMT
Rich
http://forums.parallax.com/forums/default.aspx?f=25&m=195562
@bboy: So most of my criticism was rather principally than to the point; what is left is:
Change:
by
