Make a Joule Thief
Watch Here: (4 minute video)
http://blog.makezine.com/archive/2007/11/make_a_joule_thief_weeken_1.html
I find this really interesting.
Anyone know the down side of this method?
Every method has pro's and con's.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
- - - PLJack - - -
Ran a white led at 0.5V from room light on the solar panel.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
- Stephen
instead of
Collector
LED>
GND
Use
Collector
Diode>
Capacitor
GND
to get a higher voltage for charging a 9V rechargable battery for example or making a flasher or one of those tiny solar bugs that use the 1/2 volt solar chips. (darn I just ordered stuff from those guys and i did not add those to the fun bag)
If you mean the transformer I got that from radio shack, There are two coils in a isolation transformer just like the wired ferrite coil it has 4 leads, connect one side of each coil to positive and the other two the same as the ferrite coil diagram. Be sure to read the technical stuff on how it works at this link.
http://www.evilmadscientist.com/article.php/joulethief
Beau Schwabe
IC Layout Engineer
That's the part I did not understand originally.
It seemed to me that if you increased the voltage of the source then the current would be reduced.
This circuit is cycling at ~40 kHz.
So the power source still maintains it normal current abilities.
Is that true?
- - - PLJack - - -
This circuit has been around for many, many years and it always seems to recycle in popularity. I remember this circuit from an electronics kit
I had as a kid about 30 years ago.
Anyway, a couple of things about this circuit...
- It also functions well as a VCO (Voltage controlled oscillator) meaning that as the input voltage changes, so does the frequency.
- The coil/transformer used also plays a part in determining the oscillators frequency.
- The duty cycle remains at about 40% ON 60% OFF
- Interestingly, if used as a LED driver, if the input voltage is greater than or equal to the forward bias of the LED, the oscillator will fail to oscillate...The LED remains ON..
Attached is what the waveform looks like driving a Green LED from a 1.5V "AA" battery.
The Pk-Pk voltage is about 2.84V.
The measured forward bias of the LED is 1.798V
The measured current draw while driving the LED was about 38mA
Beau Schwabe
IC Layout Engineer
