12c long eeprom addressing
I'm converting a program I wrote from James Burrows i2c driver to Mike Greens Basic_i2c_Driver, and ironically have had no problems with converting usage for other i2c devices, (an RTC, and an I/O expander), but I'm having a really hard time converting fram read/writes, even though the basic_i2c_driver is designed for it. I know it has to do with the addressing somehow. Below is a basic program, which will always save the last value written to all the registers..... (A zero in this case. Below should write 0 1 0 in registers 0-2, instead it writes 0 0 0 to them. I'm a bit confused on the syntax of the writebyte and readbyte commands.
Below is the syntax in Mike Greens Comments:
WriteByte(SCL, devSel, addrReg, data)
I would anticipate the following string to write a 1 from register $02... But it doesn't work.....
writebyte(outil_scl_i2c, $A0, 2,1)
Below is my sample program. any help would be great, or a simple example. Thanks again!
CON Page1 = %10100000 ' Fram Memory (2048bits) - Used for Good/Bad Status 1 byte per DMX Address Page2 = %10100010 Page3 = %10100100 Page4 = %10100110 Page5 = %10101000 Page6 = %10101010 Page7 = %10101100 outil_scl_i2c = 9 OBJ i2c : "Basic_i2c_Driver" PUB Mainline Write_config Read_Config PUB Write_config | i i:=1 ' Start memory counting at 1 i2c.WriteByte(outil_scl_i2c, Page7, ((i++*8)-8), 0) ' Write byte to address 0 of page 7 i2c.WriteByte(outil_scl_i2c, Page7, ((i++*8)-8), 1) ' Write byte to address 1 of page 7 i2c.WriteByte(outil_scl_i2c, Page7, ((i++*8)-8), 0) ' Write byte to address 2 of page 7 Read_config PUB Read_config | i i:=1 ' Start memory counting at 1 bValidation_enabled := i2c.readbyte(outil_scl_i2c, Page7,((i++*8)-8)) ' read byte to address 0 of page 7 bHunt_on_time := i2c.readbyte(outil_scl_i2c, Page7,((i++*8)-8)) ' read byte of address 1 of page 7 bRf_enabled := i2c.readbyte(outil_scl_i2c, Page7,((i++*8)-8)) ' read byte of address 2 of page 7 lcd.posdec(3,2,bValidation_enabled) lcd.posdec(3,7,bHunt_on_time) lcd.posdec(3,12,bRF_enabled)
Can't help you with i2c... but i love your icon... the little guy needs a propeller hat[noparse]:)[/noparse]
Rich
See the example in the comments to show how the WriteWait call works.
What's the bit with the Page1 .. Page7? That may be your problem. I had assumed that you actually had 7 EEPROM devices present. Maybe you don't. EEPROMs (unless they're 2048 bytes or less) assume that you use 2 bytes for addressing before you have to use the device select code. The I2C routines assume you're using 2 byte addressing. You should be using the same device select code for all EEPROM accesses (as long as you have only one EEPROM device ... those larger than 64K appear to be multiple devices, each 64K). If you want to have "pages" of 256 bytes, just use multiples of 256 bytes for your addresses. ($000-$0FF, $100-$1FF, etc.).
By the way, the routines in this I2C library assume that there's contiguous memory attached to the I2C bus and that what you have is a 512K address space (19 bits). The upper 3 bits get copied (OR'd) into the device select code so that you can seamlessly have up to 8 x 64K EEPROMs and treat them as a single device.
Post Edited (Mike Green) : 12/21/2007 4:23:52 PM GMT
You are aware that you do readConfig twice?
The pin programmed address of your device is %110 ?
When you talk of "registers" you mean "FRAM memory cells" I presume...
As Mike already pointed out, the device will most likely become shortly unresponsive after WritePage has flagged STOP...
Edit, BTW: What FRAM are you using... I do only find FRAMs with SPI interface
Post Edited (deSilva) : 12/21/2007 4:45:02 PM GMT
CON outil_scl_i2c : 2 OBJ i2c : "Basic_I2C_Driver" VAR byte bValidation_enabled byte bHunt_on_time byte bRf_enabled Pub Main i2c.Initialize(outil_scl_i2c) i2c.Writebyte(outil_scl_i2c, $A0, $0000, 3) i2c.Writebyte(outil_scl_i2c, $A0, $0001, 4) i2c.Writebyte(outil_scl_i2c, $A0, $0002, 5) Read_config PUB Read_config bValidation_enabled := i2c.readbyte(outil_scl_i2c, $A0,$0000) bHunt_on_time := i2c.readbyte(outil_scl_i2c, $A0,$0001) bRf_enabled := i2c.readbyte(outil_scl_i2c, $A0,$0002) lcd.posdec(4,1,i2c.devicepresent(outil_scl_i2c,$A0)) lcd.posdec(3,2,bValidation_enabled) lcd.posdec(3,7,bHunt_on_time) lcd.posdec(3,12,bRF_enabled)So I would expect to write 3,4,5 to memory cells 0,1,2. Then I perform the read, and I display the variables back and I always get 5 5 5 not 3 4 5 as I'd expect. (Or whatever value I write last). to verify it was the write and not the read, I commented out the last two reads, and still read a 5 on the first variable. So this is something with the writebyte. I attempted to add a read wait with change of results. The address of my fram is $A0, you'll notice I used a devices present function (James BUrrows) and it finds it.
Incidentally, I'm using a ramtron FM24CL16. Its spec is very close to the 24LC series from Microchip.... (Got it from Mouser).
Thanks again!
Post Edited (Chicago Mike) : 12/21/2007 5:24:22 PM GMT
(a) They do not say it's I2C I think the still fear the NXP lawyers
(b) They use a slightly different protocol: You cannot use ReadPage or WritePage which add a 16-bits byte address.
Just modify that to rather include what the datasheet calles "page" (3 bits) and "word" (8 bits) address.
Reading is a little bit more tricky, but well explained in the data sheet.
Edit: However: The FM24CL64 (and(256, 512) seem to have exactly the protocol as the 24C256 EPROMs
Post Edited (deSilva) : 12/22/2007 11:51:34 AM GMT
