Propeller Proto Board - Can it be powered via USB?
Hello Gang,
This might seem like a silly question, but I was wondering if the Propeller Proto Board with the prop-clip installed, would be able to get the power from the USB-port of the prop-plug.·· I see VSS on the prop-plug, and I assume I could get GND from the USB shield.· But is the Prop-plug giving or taking VSS?· (i.e. it is sourcing or needing VSS?)
Or would that be a bad idea?
Otherwise I will just get a wall-wart, as I know the USB would only give me like 100ma 5VDC most-likely.·
http://www.hittconsulting.com/products/propdongle/
Bean
www.iElectronicDesigns.com
Short answer: No.
Saluti Joerg
My proto boardworks great, and nominally powers a gps and servo module too.
Paul
Bean.
I use the "alternative" plug from 4D for some time now, where USB 5V is (unprotected!) available at its fifth pin. This worked fine so far.. Note that both sides of the 4D-plug differ (GND/RESET switched!) This has confused me for some time...
The layout (USB-R1) can be used as a power source for devices requiring less than 3.5V at 400mA max.
I have added an optional 28 pin DIL socket for the use with experimental boards. For easier soldering there is a top layer,
but the layout works also as a single layer PCB.
Saluti Joerg
Paul Baker
For a more save operation the following article from Elektor may be helpful:
www.elektor.de/jahrgang/2006/juli/usb-sicherung.64233.lynkx (in German)
www.elektor.com/magazines/2006/july/usb-fuse.58056.lynkx (the English version)
this is an electronic USB fuse. the article is also available in French and Netherlands.
If somebody needs a voltage above 5V, then the following design can be used:
www.elektor.de/jahrgang/2007/juli-august/usb-wandler.196790.lynkx (the original text in German)
www.elektor.com/magazines/2007/july-august/usb-converter.197508.lynkx (the English version)
a more detailed document can be found on my homepage
www.systech-gmbh.ch -> electronics -> USB-Wandler1
I hope this may helpful
Joerg
PS: it was the article for USB-Wandler1 which has introduced the Propeller chip to me. (ELEKTOR has sent me a protoboard!)
